Mac OS X Guides Guides for installing and configuring Mac OSX on your Dell Mini.
Comment
LinkBack Tutorial Tools Display Modes
  Old
mbbrocks mbbrocks is offline
Default HOWTO: Using mobile broadband / WWAN module in OSX - 01-26-2009, 12:30 PM
If you've got a Mini 9 with the Dell 5530 HSPA / Mobile Broadband module, here's what you need to know to get it going:
From http://www.mobilebroadbandrocks.com - your essential guide to Mobile Broadband
Old 11-26-2009, 11:33 AM
Default
I know the feeling, but I can tell you that the only way I got the modem to work was to install windows.
When I tried to work with it otherwise, I could "AT" the modem and it would return "OK" but it would not accept the command to turn on the WWAN portion. This has to be done with the Dell utility that actually turns on the power to the WWAN.
In terms of the Windows install, here is what I did.
When you get to the point of installing on the second partition, you need to delete the partition created for windows, recreate it and then format it as NTFS. This is the only way I got it to work. I did this with the Win7 installer, but then, instead of installing Win7, I exited and came back in with the XP installer.
I had an extra issue in that I wanted to run Win7 and to do that I had to install XP first because the disk I had was a 3-machine Home Premium Upgrade disk and would not install without having an original XP install in there.
Pain in the ass... but it did work and has continued to work. I had to do the whole process a few times to get it to get it right and BTW, if you remove the battery without having the power cord connected, the system might turn off the modem and you will have to boot into Win to turn it on again, so you have to keep the Win install around for that purpose.
I'll be happy to answer any questions that are within my (admittedly) limited knowledge.
W.
Old 11-26-2009, 12:02 PM
Default
Hi,
That's what I suspected. I'll try again I suppose.
My problem is that when I've tried to install by:
- Creating GPT partition with Win7 (200MB EFI, 40GB FAT32, 120GB other)
- Install OS X
- Back to Win7 installer and it says the BIOS doesn't support booting from the disk
Are you using the A04 BIOS?
Maybe I can try and install Win 7 on a clean disk with the GPT partition then OS X. Although saying that I also have the 3-pack upgrade so maybe I should focus first on WinXP.
Ah well, more hacking. If it wasn't for the WWAN I'd leave it as is as it's a wonderful little Mac :-D
/Trev
Old 11-26-2009, 12:07 PM
Default
I think that the fundamental difference from your method and mine is that I actually started backwards.
I installed OSX and partitioned with the OSX disk utility, creating two partitions using GUID (gparted) and as HFS+ journaled.
I then deleted the second HFS partition with the windows7 installer and _then_ created and formatted a new NTFS partition for Windows.
This worked better for me because I'm more familiar with OSX.
It was definitely worth it for me because a wonderful little Mac with built-in WWAN is even cooler.
Yes, using A04 bios
Old 11-26-2009, 12:32 PM
Default
Hmm, I'm pretty sure I've done it that way round but I'll try again.
Do you have a HDD or SSD?
I think at one point when messing about that I managed to change the disk geometry and have wondered if that is the problem although I have a nicely running OS X 10.6.2 install (which has never had any problems).
It'd be nice to know what the Dell utility is doing to switch the HW on.
Cheers,
/Trev
Old 12-01-2009, 12:45 PM
Default
I had the exact same problem about the utility in Windows 7 - once I activated it in Win7 the script posted here suddenly sprang into life on OSX.
If you're having problems dual booting windows 7 and OSX, follow the guide below
Dual Booting for Dummies - Snow Leopard with NBM 0.8.3rc2 and Windows 7
It's been updated for NBM 0.8.3 and higher.
__________________
Dell Mini 10v | 1GB | 160GB HDD | OSX 10.6.1 | NBM 0.8.3 RC2 | Windows 7 Ultimate | Ubuntu Netbook Remix | 5530 WWAN Vodafone UK
Old 02-17-2010, 01:24 AM
Default Cant see the Dell 5530 under Network perf
Hi guys.
Can anyone help me with this.
I put the script in the right location as per guide.
And when i got to Network interface i cant see Dell 5530 and also the same when i click on the "+" i only get
Airport
Ethernet
Bluetooth
VPN
PPPoE
6 to 4
I am 100% i have the card installed as this worked under XP and Ubuntu.
I can also see the card under About This Mac -> More Info -> Hardware -> USB.
Can anyone help me with this? where can i get the drivers from, etc?
Thanks
Hane
Old 02-25-2010, 02:43 PM
Default
Just wanted to say thanks for this post- have finally managed to get my Mini9 working with an O2 Simplicity SIM from my iPhone.
Was just wondering if anyone knew of a way or a good program which monitored the amount of data being sent/received when using the 3G card? Worth remembering that although mobile phone providers say 'unlimited' browsing, it is normally only around 250mg, which can quickly be got through when using the real web.
Thanks in advance
__________________
Dell Mini 9 : OSX 10.6.2 : 0.8.3 NBI Final : BIOS A05
32GB Super Talent SSD : 2GB RAM
3G Modem - Working on O2 Simplicity
Bluetooth - Working
Audio/Mic - Working modified AppleHDA/IOAudioFamily
Old 02-27-2010, 12:07 AM
Default
Originally Posted by indie1776 View Post
UPDATE
Can anyone offer any advice on how to get the original script on this thread to work in OS X 10.6.1?
Thanks
indie1776,
Did you ever get this working? I'm running the same Dell card on my Studio 14z running 10.6.2, and I'm getting the following on my tail log:
Fri Feb 26 18:59:38 2010 : Apple Base Script.ccl Version 3.3
Fri Feb 26 18:59:38 2010 : Initializing phone: AT&FE0Q0V1
Fri Feb 26 18:59:38 2010 : Initializing PDP context: AT+CGDCONT=1,"IP","isp.cingular.com"
Fri Feb 26 18:59:38 2010 : Dialing: ATD*99***1#
Fri Feb 26 18:59:38 2010 : Waiting for connection
Fri Feb 26 18:59:39 2010 : Connection established
Fri Feb 26 18:59:42 2010 : Serial connection established.
Fri Feb 26 18:59:42 2010 : Using interface ppp0
Fri Feb 26 18:59:42 2010 : Connect: ppp0 <--> /dev/cu.usbmodem2472
Fri Feb 26 18:59:43 2010 : CHAP authentication succeeded: Congratulations!
Fri Feb 26 18:59:43 2010 : LCP terminated by peer
Fri Feb 26 18:59:46 2010 : Connection terminated.
Fri Feb 26 18:59:56 2010 : Serial link disconnected.
Old 03-01-2010, 01:06 AM
Default
Thanks in advance
Hey Larry.
Rakmini posted this a while back called surplusmeter, I havent had a chance to install it yet but it looks promising
Originally Posted by rakmini View Post
Here's an app that can track data usage: SurplusMeter. It has lots of options to match your billing cycle, and it's free! -- tutorial/review here
Old 03-02-2010, 05:17 AM
Default
Originally Posted by tamorgen View Post
indie1776,
Anyone? This seems to have worked in the past. It works fine in Windows 7, running Sony Ericcsons wireless manager. AT&T's Wireless manage is garbage. Worked like once, then couldn't see it anymore.
Still trying to get this to run in OSX though. I'm running 10.6.2. There has to be a solution, and yes I do have the scripts.
Comment
« Snow Leopard on Mini 9 from scratch without a Mac? | How to Upgrade Bios While Running Mac OS X/Ubuntu »
Tutorial Tools
LinkBack to this Thread: http://www.mydellmini.com/forum/mac-os-x-guides/2910-howto-using-mobile-broadband-wwan-module-osx.html
Posted By For Type Date
tonymacx86 Forum &bull; View topic - ThinkPad X121e Sandy Bridge HD 3000 running 10.7 Lion osx86 This thread Refback Yesterday 07:26 PM
What is MOBILE BROADBAND MODULE? This thread Refback 07-13-2011 12:10 PM
?????-???????? : CheetahWatch ZTE ??????? This thread Refback 12-18-2010 01:20 AM
ClickProtect This thread Refback 07-02-2010 09:43 PM
PDAMobiz.com Forum: OSX Snow LEopard NETBook ?!! This thread Refback 06-29-2010 04:25 PM
PDAMobiz.com Forum: OSX Snow LEopard NETBook ?!! This thread Refback 06-29-2010 01:57 AM
ÁÒãªéOSX Snow LEopard ã¹NETBook ¡Ñ¹à¶ÍÐ!!:PDAMobiz.com Forum This thread Refback 05-26-2010 04:24 AM
PDAMobiz.com Forum: ÁÒãªéOSX Snow LEopard ã¹NETBook ¡Ñ¹à¶ÍÐ!! This thread Refback 04-07-2010 12:35 PM
Lenovo IdeaPad S Series Forum &bull; View topic - Snow Leopard Booting On My S10 This thread Refback 01-30-2010 11:15 AM
Enabling GPS on Dell 5530 WWAN module | Mobile Broadband Rocks! This thread Refback 12-03-2009 09:59 PM
Vodafone / Dell Inspiron Mini 9 running Mac OS X | Mobile Broadband Rocks! This thread Refback 12-03-2009 07:49 PM
m1530_snow_leopard_install [KungFuMonkay] This thread Refback 11-15-2009 01:59 PM
PDAMobiz.com Forum: ÁÒãªéOSX Snow LEopard ã¹NETBook ¡Ñ¹à¶ÍÐ!! This thread Refback 11-01-2009 04:02 AM
HOWTO: Using mobile broadband / WWAN module in OSX This thread Refback 09-13-2009 06:26 PM
Mac OS X Guides This thread Refback 06-26-2009 07:52 PM
Vodafone / Dell Inspiron Mini 9 running Mac OS X | MobileBroadbandRocks.com This thread Refback 06-26-2009 07:45 AM
How-To: Install Mac OS X - DellEFI Method - MyDellMini This thread Refback 06-11-2009 11:46 AM
HOWTO: Using mobile broadband / WWAN module in OSX - MyDellMini This thread Refback 05-13-2009 07:23 PM
