Mac OS X Guides Guides for installing and configuring Mac OSX on your Dell Mini.
| | LinkBack | Article Tools | Display Modes |
| by mbbrocks 01-26-2009, 11:30 AM
If you've got a Mini 9 with the Dell 5530 HSPA / Mobile Broadband module, here's what you need to know to get it going:
If you're having problems, you may need to enter your APN manually. Back in the connection properties, change the 'telephone number' to the name of your APN. The APN will vary depending on which mobile operator you use - for example, if you're a contract Vodafone UK customer, the APN will be 'internet'. Try http://www.filesaveas.com/gprs.html for details on UK APNs.
__________________ From http://www.mobilebroadbandrocks.com - your essential guide to Mobile Broadband |
| Views 51527
Comments 82
(#11)
(#12)
| Member Posts: 95 Join Date: Jan 2009 | Really stupid question folks, but is there any reason why the Vodafone Mobile Connect application for Mac OS X doesn't work? I can get the modem script working fine, but I thought I'd try the VMC app. However, whilst it installs OK, it never seems to detect the modem. Furthermore, if you try and do anything in the program apart from edit the preferences or close it, it locks the OS and tells you you have to hard reset the Mac. Any thoughts? http://www.business.vodafone.com/sit...test/p_mac.jsp Dell Mini 9: Obsidian Black | A05 | Win7 / OS X 10.5.6 Dual Boot | DellEFI 1.1 | 2GB RAM | 64GB RunCore 70mm SSD | 4GB SDHC | Vodafone HSPA | 0.3mP webcam Dell Mini 9: Obsidian Black | as above except: XP Pro SP3 | 250GB USB HDD |
(#13)
| Member Posts: 95 Join Date: Jan 2009 | So I've managed to answer my own stupid question. The OS X version of Vodafone Mobile Connect only supports the modems listed in the readme: [attachment=0:2w8atg3t]VMC_for_Mac-2.11.02.00-ReadMe_v1.2.pdf[/attachment:2w8atg3t] Ideally Vodafone will see sense and add support for our lowly 5530/f4507. However, in the mean time, is there a way of hacking the app to support the 5530? I have zero experience of mac apps, but I have huge ambition :lol: Dell Mini 9: Obsidian Black | A05 | Win7 / OS X 10.5.6 Dual Boot | DellEFI 1.1 | 2GB RAM | 64GB RunCore 70mm SSD | 4GB SDHC | Vodafone HSPA | 0.3mP webcam Dell Mini 9: Obsidian Black | as above except: XP Pro SP3 | 250GB USB HDD |
(#14)
(#15)
(#16)
| Member Posts: 45 Join Date: Mar 2009 | I'm also getting, er, 'variable' performance from 3G in that sometimes it works, sometimes it doesn't (ppp fail to connect). Interesting when I was attempting this in linux it would fail at exact same stage, specifically ppp disconnect from the far end when trying to establish LCP. But in linux it would fail every single time. More often than not it doesn't work. Also sometimes clearing the config and re-entering the settings works (but rarely). I am totally confused as to the variable performance Australia, carrier is Three on prepaid broadband. |
(#17)
| Member Posts: 77 Join Date: Mar 2009 | Does any body know which dvd drives I cannot use for the mac osx installation? Can I use a hp one from walmart? |
(#18)
| Member Posts: 45 Join Date: Mar 2009 | I'm also getting the ppp disconnect issue. A debug of my /var/log/messages reveals its a LCP disconnection being initiated from the peer i.e. the carrier is sending a disconnect frame. This occurs just as I'm sending out IPCP requests. HOWEVER this is totally inconsistent - sometimes it works, sometimes above issue happens. I can find no rhyme or reason!!!!!!!!!!!! However it NEVER works if you disconnect from a working connection and test it again. Another poster summed it up best: "If I restart, or try again later, without even changing any settings, it will tend to fix itself, and I'll be able to connect fine. However sometimes I'll continue to have a really long string of unsuccessful connection attempts." Also sometimes I delete the config and put it in again and it works once (but as noted above never twice). Does anyone else experience this issue?!?!?! It happens to me with 2 different sims on 2 different carriers here in Aust (3 prepaid and Telstra nextg respectively). |
(#19)
| Junior Member Posts: 1 Join Date: Mar 2009 | Can anybody tell me how to put the script in the Modem Library folder please, I have downloaded the "Dell Mobile Broadband" Unix File but if I try to expand/open it it just runs a terminal screen, Sorry to seem thick but I'm new to Mac/Unix code. Thanks |
(#20)
| Junior Member Posts: 8 Join Date: Apr 2009 | Thanks to this forum: running Dell Mini 9 OS X with DellEFI1.2a5 and Modem Script. ![]() Tried every combination and searched the whole web... Unfortunately NO mobile broadband connection! Carrier: Vodafone Germany (used the correct APN)Error message: "Could not negotiate a connection with the remote PPP server." Does anyone have an idea how to solve this!? I appreciate any help! |
| Article Tools | |
LinkBack to this Thread: http://www.mydellmini.com/forum/mac-os-x-guides/2910-howto-using-mobile-broadband-wwan-module-osx.html | ||||
| ClickProtect | This thread | Refback | 07-02-2010 08:43 PM | |
| PDAMobiz.com Forum: OSX Snow LEopard NETBook ?!! | This thread | Refback | 06-29-2010 03:25 PM | |
| PDAMobiz.com Forum: OSX Snow LEopard NETBook ?!! | This thread | Refback | 06-29-2010 12:57 AM | |
| ÁÒãªéOSX Snow LEopard ã¹NETBook ¡Ñ¹à¶ÍÐ!!:PDAMobiz.com Forum | This thread | Refback | 05-26-2010 03:24 AM | |
| PDAMobiz.com Forum: ÁÒãªéOSX Snow LEopard ã¹NETBook ¡Ñ¹à¶ÍÐ!! | This thread | Refback | 04-07-2010 11:35 AM | |
| Lenovo IdeaPad S Series Forum • View topic - Snow Leopard Booting On My S10 | This thread | Refback | 01-30-2010 10:15 AM | |
| Enabling GPS on Dell 5530 WWAN module | Mobile Broadband Rocks! | This thread | Refback | 12-03-2009 08:59 PM | |
| Vodafone / Dell Inspiron Mini 9 running Mac OS X | Mobile Broadband Rocks! | This thread | Refback | 12-03-2009 06:49 PM | |
| m1530_snow_leopard_install [KungFuMonkay] | This thread | Refback | 11-15-2009 12:59 PM | |
| PDAMobiz.com Forum: ÁÒãªéOSX Snow LEopard ã¹NETBook ¡Ñ¹à¶ÍÐ!! | This thread | Refback | 11-01-2009 03:02 AM | |
| HOWTO: Using mobile broadband / WWAN module in OSX | This thread | Refback | 09-13-2009 05:26 PM | |
| Mac OS X Guides | This thread | Refback | 06-26-2009 06:52 PM | |
| Vodafone / Dell Inspiron Mini 9 running Mac OS X | MobileBroadbandRocks.com | This thread | Refback | 06-26-2009 06:45 AM | |
| How-To: Install Mac OS X - DellEFI Method - MyDellMini | This thread | Refback | 06-11-2009 10:46 AM | |
| HOWTO: Using mobile broadband / WWAN module in OSX - MyDellMini | This thread | Refback | 05-13-2009 06:23 PM | |
