View Poll Results:
0 0%
  (#211) Old
Default 09-05-2009, 02:01 PM
Originally Posted by lnxneo View Post
If you get codec dump from linux (see here), I could take a look it and see what I can do.
Thanks again!
This is my code in Ubuntu.
  (#212) Old
Default 09-06-2009, 05:41 AM
Originally Posted by waneto2008 View Post
Thanks again!
Give this LegacyHDA a try. Please post your audio screenshot under System Profiler. And run "sudo dmesg" and let me know the output.
Mini10v|N270|160G HD|2G RAM|BCM2046|BCM4322
  (#213) Old
Default You made it !!! - 09-06-2009, 11:14 AM
Newest Update: Soryy ,lnxneo, sometimes it will got panic again, don't knwo why.
lnxneo, You are my hero!!! you made it, I can use your legacyHDA+AppleHDA normally, and no kernel panic, everything looks ok now on my IdeaPad Y550A @ Leopard 10.5.8.
Thank you so much, you know, we here a lot of people bought the Y550A, you help us so much, thanks really!!
Here r my sudo Dmesg and audio system profiles:
Code:
Sound assertion "0 == pathMap_aDriverInstance" failed in "/SourceCache/AppleHDA/AppleHDA-171.1.2/AppleHDA/AppleHDADriver.cpp" at line 1459 goto Exit
Sound assertion "0 != createAudioEngines ( fPathMap_aDriverInstance )" failed in "/SourceCache/AppleHDA/AppleHDA-171.1.2/AppleHDA/AppleHDADriver.cpp" at line 172 goto Exit
I also try your legacyHDA on Snow leopard 10A432, but no work, here is the Dmesg:
Code:
Sound assertion "0 == pathMap_aDriverInstance" failed in "/SourceCache/AppleHDA/AppleHDA-174.1.1/AppleHDA/AppleHDADriver.cpp" at line 1459 goto ExitSound assertion "0 == pathMap_aDriverInstance" failed in "/SourceCache/AppleHDA/AppleHDA-174.1.1/AppleHDA/AppleHDADriver.cpp" at line 1459 goto Exit
Sound assertion "0 != createAudioEngines ( fPathMap_aDriverInstance )" failed in "/SourceCache/AppleHDA/AppleHDA-174.1.1/AppleHDA/AppleHDADriver.cpp" at line 172 goto Exit
DSMOS has arrivedSound assertion "0 == pathMap_aDriverInstance" failed in "/SourceCache/AppleHDA/AppleHDA-174.1.1/AppleHDA/AppleHDADriver.cpp" at line 1459 goto Exit
  (#214) Old
Default 09-06-2009, 01:53 PM
Code:
Code:
Can you change your system from "Mac Pro" to "MacAir"? and let me know the dmesg output.
  (#215) Old
Default 09-06-2009, 02:22 PM
How to do that:
(1)Can you change your system from "Mac Pro" to "MacAir"?
(2)dmesg output
thank you!
  (#216) Old
Default 09-06-2009, 03:39 PM
How to do that:
(2)dmesg output
thank you!
1) Change it in smbios.plist
2) "sudo dmesg"
  (#217) Old
Default 09-06-2009, 06:58 PM
2) "sudo dmesg"
Thanks! lnxneo,this the sudo dmesg on leopard 10.5.8 @ macbookair1,1 when the legacyhda+dsdt+AppleHDA works well. but sometimes it go panic.
Code:
Password:
 Policy (mb)
Loading security extension com.apple.security.TMSafetyNet
calling mpo_policy_init for TMSafetyNet
Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Copyright (c) 1982, 1986, 1989, 1991, 1993
 The Regents of the University of California. All rights reserved.
MAC Framework successfully initialized
using 16384 buffer headers and 4096 cluster IO buffer headers
IOAPIC: Version 0x20 Vectors 64:87
PS2Controller: Created dev /ps2controller
Using new IRQ layout 0,1
ACPI: System State [S0 S3 S4 S5] (S3)
Extension "com.apple.driver.AppleACPIPlatform" has immediate dependencies on both com.apple.kernel and com.apple.kpi components; use only one style.
mbinit: done
Security auditing service present
BSM auditing present
From path: "uuid",
Waiting for boot volume with UUID C08250B6-CB4B-3E99-9E2B-7B034C56E397
Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SAT0@1F,2/AppleAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/WDC WD3200BEVT-22ZCT0 Media/IOFDiskPartitionScheme/Untitled 3@3
BSD root: disk0s3, major 14, minor 4
Extension "com.apple.driver.iTunesPhoneDriver" has no explicit kernel dependency; using version 6.0.
Jettisoning kernel linker.
Resetting IOCatalogue.
GFX0: family specific matching fails
Matching service count = 1
Matching service count = 2
Matching service count = 5
MacBookAir1,1: match category AppleTyMCEDriver exists
BCM5751Enet: Ethernet address ba:ad:f0:0d:ba:ad
NVDANV50HAL loaded and registered.
VoodooPS2SynapticsTouchPad loaded
[HCIController][configurePM] power parent ready after 1 tries
VoodooPS2Trackpad: Synaptics TouchPad v7.2
VoodooBattery.kext: VoodooBattery.kext 1.2.1 (Release) Apr  7 2009 02:25:24 [1050]
VoodooBattery.kext: (C) 2009 Superhai, All Rights Reserved
Matching service count = 0
VoodooBattery.kext: [Warning] Battery 0 has no remaining capacity reported
ACPI_SMC_PlatformPlugin::start - waitForService(resourceMatching(AppleIntelCPUPowerManagement) timed out
VoodooPower.kext: VoodooPower.kext 1.2.3 (Release) Feb 15 2009 17:34:22 [1050]
VoodooPower.kext: (C) 2008-09 Superhai, All Rights Reserved
NTFS driver 2.1 [Flags: R/O].
NTFS volume name Win7, version 3.1.
NTFS volume name iWork, version 3.1.
NTFS volume name iMuse, version 3.1.
This is my smbios.plist:
Code:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
 <key>SMbiosvendor</key>
 <string>Apple Inc.</string>
 <key>SMbiosversion</key>
 <string>MP21.88Z.005C.B01.0608221120</string>
 <key>SMbiosdate</key>
 <string>04/01/2008</string>
 <key>SMboardmanufacturer</key>
 <string>Apple Computer, Inc.</string>
 <key>SMboardproduct</key>
 <string>Mac-F4208DC8</string>
 <key>SMfamily</key>
 <string>MacBookAir</string>
 <key>SMmanufacturer</key>
 <key>SMproductname</key>
 <string>MacBookAir1,1</string>
 <key>SMserial</key>
 <string>W88033AKY51</string>
 <key>SMsystemversion</key>
 <string>1.0</string>
 <key>SMUUID</key>
 <string>00000000-0000-1000-8000-000000000000</string>
 <key>SMmemtype</key>
 <string>24</string>
 <key>SMmemspeed</key>
 <string>1600</string>
 <key>SMmemmanufacter</key>
 <string>Apple Computer Inc.</string>
<key>SMmempart_1</key>
   <string>0x48594D503131325336344350362D59352020</string>
   <key>SMmempart_2</key>
   <key>SMmemserial_1</key>
   <string>0x00001020</string>
   <key>SMmemserial_2</key>
   <string>0x00003021</string>
 <key>SMexternalclock</key>
 <string></string>
 <key>SMmaximalclock</key>
 <string></string>
</dict>
</plist>
  (#218) Old
Default 09-06-2009, 09:55 PM
Code:
<dict>
 <key>SMfamily</key>
 <key>SMserial</key>
 <key>SMUUID</key>
 <string>24</string>
 <string></string>
 <string></string>
</dict>
</plist>
In smbios.plist, you need change some settings as the following to match MacAir.
Code:
        <string>MBA11.88Z.00BB.B00.0712201139</string>
        <key>Board Id</key>
        <string>Mac-F42C8CC8</string>
And try this new legacyhda, and let me out the output of command "sudo dmesg"
  (#219) Old
Default 09-07-2009, 09:27 AM
Code:
        <key>Board Id</key>
Again, at first I succeed, then restart it go panic, look my dmesg from my scrennshots by iphone(there r two situations,so I took 2 pictures):
  (#220) Old
Default 09-08-2009, 01:48 PM
It seems that vanilla applehda does not like some configurations injected by LegacyAppleHDA. I double checked the legacyapplehda file, and didn't find any thing obviously wrong. Unfortunately, I don't have the unit to tinker with. Mmy recommendation is to go back to VoodooHDA if it works for you for time being, sorry.
al272, audio, dsdt
« Find/Dev Kexts | FakeSMC Editing »
LinkBack to this Thread: http://www.mydellmini.com/forum/mac-os-x-development/10965-building-100-vanilla-10v-starting-fully-working-audio.html
Posted By For Type Date
???????? : dell This thread Refback 10-02-2009 02:20 AM
ALC272 @ich9M drivers for Sow - InfiniteMac OSx86 Community This thread Refback 09-01-2009 10:53 AM
(Solved)Need Help Patching New AppleHDA Kext - InfiniteMac OSx86 Community This thread Refback 08-31-2009 11:08 AM
Need Help Patching New AppleHDA Kext - InfiniteMac OSx86 Community This thread Refback 08-30-2009 06:44 PM
DSDT - Vanilla Speedstep - Remove _cst errors for MB without C-states - InsanelyMac Forum This thread Refback 08-26-2009 10:48 AM
netputing.com • View topic - Experience with NetbookBootMaker 0.8.1 and 10v This thread Refback 08-25-2009 02:16 AM
MyDellMini | Site profile | BoardReader This thread Refback 08-22-2009 08:11 AM
???????? This thread Refback 08-22-2009 01:41 AM
???????? : 2009?08? This thread Refback 08-11-2009 07:23 AM
De muzzle HCL (hardware compatible list) - Muzzle.nl This thread Refback 08-07-2009 07:30 PM
netputing.com • View topic - Experience with NetbookBootMaker 0.8.1 and 10v This thread Refback 08-05-2009 08:45 PM
???????? : Macintosh This thread Refback 08-03-2009 02:31 PM
???????? : Dell Inspiron mini 10v OSX This thread Refback 08-03-2009 04:57 AM
???????? : MacBook mini This thread Refback 08-03-2009 02:15 AM
InsanelyMac Forum > Building 100% Vanilla osx on Dell mini 10v (In progress, audio now is fully working) This thread Refback 08-02-2009 09:29 PM
Building 100% Vanilla osx on Dell mini 10v (In progress, audio now is fully working) - InsanelyMac Forum This thread Refback 08-02-2009 05:05 AM
ciaconne's Bookmarks on Delicious This thread Refback 08-01-2009 09:06 AM
