| View Poll Results: | |||
| | 0 | 0% | |
| Voters: 0. You may not vote on this poll | |||
(#151)
(#152)
| Senior Member Posts: 105 Join Date: Jan 2009 Location: Los Angeles, CA | Quote:
(#153)
| Member Posts: 89 Join Date: Jul 2009 | not using netbookmaker or installer (where i think some of the confusion is happening in regards to so many different types of installation configurations) when installing. doing 2 usb method when installing, original MAC OS X 10.5.6 DVD imaged to a usb drive.....Ended up Reloading the whole thing, too late last night to try the kext stuff again i'll try just loading the 4 kext and see what happens now. So, since i've loaded 10.5.7 and i've not touched the extensions area...all i should have to do is install LegacyAppletHDA, HDAInstaller and VerbHelper...is that right? failed again...loaded the 4 kext with a FRESH install of macosx...nothin...guess i'll try deleting and remaking the dsdt file i may have to go back to the original voodoo file with the static, at least i had sound. saw where someone deleted their virtualaudio kext from extensions and got it to work..no work here. also, which portions of the steps need to be done in safe mode, if any. guess i'll wipe it again..made so many changes i've had to mess something up, not getting anything in system profiler now for the sound. |
(#154)
Than you should install these kexts (all of which are in Post #1): AppleHDA ("Vanilla" in the green text in the body of Post #1) IOAudioFamily ("Vanilla" again) HDAEnabler LegacyAppleHDA VerbHelper The last three are at the end of the post. ...and cross your fingers. You can see it wasn't easy for me either. | |
(#155)
| Member Posts: 89 Join Date: Jul 2009 | so any file with HDA in it should be eliminated or only audio related ones. If i have a fresh install of 10.5.7 i shouldn't need to touch the applehda or ioaudio files should i? |
(#156)
(#157)
| Junior Member Posts: 28 Join Date: Jun 2009 | I couldn't modify the contents of the NetBookInstaller on the 8 GB USB install drive, so after Installing the 10.5.7 update, I removed AppleHDA.kext from the Applications/NetbookInstaller.app/Contents/Resources/SupportFiles/Extensions/Mini 10v Extensions/. I then added the 5 kexts. I ran NetBookInstaller checking Install Extensions and make dsdt file. I left Remote CD checked as well. This seemed to go okay and I rebooted. Upon reboot, no audio and when I went to System Preferences->Sound, no output/input audio devices. Before doing this method, I had audio (internal speaker only no headphone) using the 4 kext and kextHelper0.7 install procedure outlined in http://www.mydellmini.com/forum/mac-...-audio-45.html post number 442. The 4 kext install doesn't use the IOAudioFamily.kext for some reason. I'm not sure what to do next, but plan on redoing using the 4 kext method and see what happens. A little audio is better than none. |
(#158)
| Member Posts: 89 Join Date: Jul 2009 | i'm trying to make an image of this 10.5.8 now, i'd hate to reinstall (again), that's like 4 times in the past 24 hours. everything else works like a dream, even installed my HP printer that's on my network (by guessing which file the mac wanted to see since they didn't have mine listed). tempted to go back to voodoo but that static bugged the crap out of me |
(#159)
(#160)
| Member Posts: 89 Join Date: Jul 2009 | i'm sure eventually someone will release a step by step guide for each installation type (1 usb, 2 usb, netboot, ) because apparently there's something different between how i installed my mac osx (2 usb method and dell efi 1.1) and how people who have it working installed (alot seem to be using dell efi 12a5 though i had a couple problems with that one). Wifi works, BT works, printer works, everything i've tried works except the sound. So there must be some magical element somewhere (dsdt?) that is the trigger. In regards to uninstalling kext files, is it just a matter of dragging to the trash can the text and it's completly removed or is there some other process (uninstall program). Does anything at all have to be done with the Extensions.mkext once you start mucking with the kext files....was reading where you should delete that file and reboot once you delete or change a kext, guessing it rebuilds itself. also, is it normal to have 3 total extensions.mkext files....i have a externsions.mkext in the EXTRA folder and i also have a extensions.mkext in system/library and a extensions.mkext.e5m5 in the system/library... |
| Tags |
| al272, audio, dsdt |
LinkBack to this Thread: http://www.mydellmini.com/forum/mac-os-x-development/10965-building-100-vanilla-10v-starting-fully-working-audio.html | ||||
| ???????? : dell | This thread | Refback | 10-02-2009 01:20 AM | |
| ALC272 @ich9M drivers for Sow - InfiniteMac OSx86 Community | This thread | Refback | 09-01-2009 09:53 AM | |
| (Solved)Need Help Patching New AppleHDA Kext - InfiniteMac OSx86 Community | This thread | Refback | 08-31-2009 10:08 AM | |
| Need Help Patching New AppleHDA Kext - InfiniteMac OSx86 Community | This thread | Refback | 08-30-2009 05:44 PM | |
| DSDT - Vanilla Speedstep - Remove _cst errors for MB without C-states - InsanelyMac Forum | This thread | Refback | 08-26-2009 09:48 AM | |
| netputing.com • View topic - Experience with NetbookBootMaker 0.8.1 and 10v | This thread | Refback | 08-25-2009 01:16 AM | |
| MyDellMini | Site profile | BoardReader | This thread | Refback | 08-22-2009 07:11 AM | |
| ???????? | This thread | Refback | 08-22-2009 12:41 AM | |
| ???????? : 2009?08? | This thread | Refback | 08-11-2009 06:23 AM | |
| De muzzle HCL (hardware compatible list) - Muzzle.nl | This thread | Refback | 08-07-2009 06:30 PM | |
| netputing.com • View topic - Experience with NetbookBootMaker 0.8.1 and 10v | This thread | Refback | 08-05-2009 07:45 PM | |
| ???????? : Macintosh | This thread | Refback | 08-03-2009 01:31 PM | |
| ???????? : Dell Inspiron mini 10v OSX | This thread | Refback | 08-03-2009 03:57 AM | |
| ???????? : MacBook mini | This thread | Refback | 08-03-2009 01:15 AM | |
| InsanelyMac Forum > Building 100% Vanilla osx on Dell mini 10v (In progress, audio now is fully working) | This thread | Refback | 08-02-2009 08:29 PM | |
| Building 100% Vanilla osx on Dell mini 10v (In progress, audio now is fully working) - InsanelyMac Forum | This thread | Refback | 08-02-2009 04:05 AM | |
| ciaconne's Bookmarks on Delicious | This thread | Refback | 08-01-2009 08:06 AM | |
