View Poll Results:
0 0%
  (#101) Old
Default 08-01-2009, 02:23 AM
No problem. Your effort is greatly appreciated, and I still consider the audio driver a home run!
Let me know if you have anything else you'd like me to try.
Mini 10v - Obsidian Black - 2 GB RAM - 120 GB HD - Bios A04 - OS X Snow Leopard 10.6.2
http://osx.mechdrew.com/
  (#102) Old
Default 08-01-2009, 02:43 AM
Nick, would you replace LegacyAppleHDA.kext with the newer one in this post?
  (#103) Old
Default 08-01-2009, 03:03 AM
I used kexthelper to install the new legacyAppleHDA kext. Same thing, no mute on headphones.
I did not delete the old LegacyAppleHDA kext that was installed. I assumed that kexthelper would overwrite it with the new version.
  (#104) Old
meklort's Avatar
Default 08-01-2009, 03:09 AM
I;m going to suggest that you remove IOAudioFamily.kext from /Extra as verbHelper replaces it's functionality and might be causing a conflict.
  (#105) Old
Default 08-01-2009, 03:17 AM
I don't see IOAudioFamily.kext in my Extra folder, would it be anywhere else?
  (#106) Old
meklort's Avatar
Default 08-01-2009, 03:21 AM
It's either in /Extra/Mini9Ext /Extra/Mini10vExt or it was installed over the version included by Apple in /System/Library/Extensions. You'll have to replace it in that case w/ the correct version.
  (#107) Old
Default 08-01-2009, 03:24 AM
Ok, the only one I see is located in System/Library/Extensions.
What do you mean by replacing it with the correct version? Do you mean a version of the kext from a real mac install?
  (#108) Old
meklort's Avatar
Default 08-01-2009, 04:26 AM
I mean the version included with whatever version of OS X you are running, so if you are on 10.5.7, then replace it with that one.
  (#109) Old
Default 08-01-2009, 05:26 AM
OK, these last updates have fixed all of my problems!! In particular, the new LegacyHDA kext and the IOAudioFamily (stock is uploaded) patch have fixed my problems. For anyone who wants to try what I've done, here are the steps for anyone who wants to try this the way I did:
1. Remove VoodooHDA.kext, AppleHDA.kext, and IOAudioFamily.kext from /Extra/Mini9Ext and/or /System/Library/Extensions/
2. Patch the DSDT with new audio settings (see post 75)
3. Get the kexts: VerbHelper from post 1, my AppleHDA from post 16, the latest LegacyAppleHDA from post 102, and IOAudioFamily from this post.
4. Use kext helper to install all of these (into S/L/E)
5. Reboot. Enjoy.
Thanks to everyone who has posted in this thread; these new audio drivers have been a huge success!!
Dell mini 10v: N270, 2GB RAM, 120GB HD, A03, no BT, OSX 10.6.1
  (#110) Old
Default 08-01-2009, 05:27 AM
Originally Posted by lnxneo View Post
Check if anything in /Extra directory.
found a appleHDA in /extra/mini10vext/. removed it and used the "update extra" to regenerate the Extensions.ktext in the /extra folder. Reboot.
After this no sound device is listed, even after I drop the four ktext files attached here into /system/libraries/extensions/ folder. In short, while the appleHDA was cleared, the new ktext files for some reason just wouldn't register.
Do I need to do something to make them valid? Again this is the NetbookInstall 0.8.1alpha packages that I'm using. Thanks for any help/tips.
al272, audio, dsdt
« Find/Dev Kexts | FakeSMC Editing »
LinkBack to this Thread: http://www.mydellmini.com/forum/mac-os-x-development/10965-building-100-vanilla-10v-starting-fully-working-audio.html
Posted By For Type Date
???????? : dell This thread Refback 10-02-2009 01:20 AM
ALC272 @ich9M drivers for Sow - InfiniteMac OSx86 Community This thread Refback 09-01-2009 09:53 AM
(Solved)Need Help Patching New AppleHDA Kext - InfiniteMac OSx86 Community This thread Refback 08-31-2009 10:08 AM
Need Help Patching New AppleHDA Kext - InfiniteMac OSx86 Community This thread Refback 08-30-2009 05:44 PM
DSDT - Vanilla Speedstep - Remove _cst errors for MB without C-states - InsanelyMac Forum This thread Refback 08-26-2009 09:48 AM
netputing.com • View topic - Experience with NetbookBootMaker 0.8.1 and 10v This thread Refback 08-25-2009 01:16 AM
MyDellMini | Site profile | BoardReader This thread Refback 08-22-2009 07:11 AM
???????? This thread Refback 08-22-2009 12:41 AM
???????? : 2009?08? This thread Refback 08-11-2009 06:23 AM
De muzzle HCL (hardware compatible list) - Muzzle.nl This thread Refback 08-07-2009 06:30 PM
netputing.com • View topic - Experience with NetbookBootMaker 0.8.1 and 10v This thread Refback 08-05-2009 07:45 PM
???????? : Macintosh This thread Refback 08-03-2009 01:31 PM
???????? : Dell Inspiron mini 10v OSX This thread Refback 08-03-2009 03:57 AM
???????? : MacBook mini This thread Refback 08-03-2009 01:15 AM
InsanelyMac Forum > Building 100% Vanilla osx on Dell mini 10v (In progress, audio now is fully working) This thread Refback 08-02-2009 08:29 PM
Building 100% Vanilla osx on Dell mini 10v (In progress, audio now is fully working) - InsanelyMac Forum This thread Refback 08-02-2009 04:05 AM
ciaconne's Bookmarks on Delicious This thread Refback 08-01-2009 08:06 AM
