Default 07-03-2009, 05:24 PM
Originally Posted by DMBryant View Post
FIXED!!!!
I didn't realise I had to delete the AppleHDA.kext from the Extensions folder, d'oh!!!
The Volume icon disappears after wake up but, to be honest, how often is that actually used anyway??? I think I'll leave it turned off :-)
Hi - So what exactly is the FIX - could you please summarize the steps? cheers.
DMBryant's Avatar
Default 07-05-2009, 09:07 PM
1. Download and install the VoodooHDA kext from detailed in this post:
http://www.mydellmini.com/forum/mac-...html#post71522
2. Follow the steps in post 2 or post 5 of this thread.
3. Delete the file 'AppleHDA.kext' from the /System/Library/Extensions folder.
Thats it. Hope that helps :-)
Default 07-23-2009, 04:44 PM
Originally Posted by Nick Gertz View Post
I was using the command to make it reappear using the script but sometimes it would cause the menu bar to get mixed up so i decided its no big deal to not have it.
Out of curiosity, what's the command? I'd love to get the icon to re-appear.
Inspiron 6000 "Scheherazade" Ubuntu 10.04
iMac G4 (17") "Snow Maiden" MacOS 10.5.8
Mini 10v "Bumblebee" MacOS 10.6.4 / NBI 20100616...
  (#14) Old
soul's Avatar
Default 07-23-2009, 06:22 PM
I'ma give that a shot, thanks you guys. Report back later
Mini 10V | 1.6GHz | 2GB | 16GB SSD | GMA 950 | OSX | ~$180ish | Wireless-N | 6-Cell |
M1340 | 2.4GHz x2 | 4GB | 320GB 7.2K-RPM | Nvidia SLi 9400M + 9200GS | 7-RTM | $500.00 | WEI: 5.3 |
  (#15) Old
Default 08-03-2009, 11:07 PM
mine was working until i installed 10.5.7...then the static came...i'm guessing it reinstalled the applehd file with the update, as i found it again in the extensions folder...once i deleted it the static stopped.
  (#16) Old
Default 08-03-2009, 11:50 PM
for some reason i can't find my "extensions" folder on my computer. i looked under library. what am i doing wrong?
  (#17) Old
Default 08-04-2009, 10:20 PM
bah, my static is back....installed divx and perian codec wonder if that killed something.
  (#18) Old
Default 09-06-2009, 04:30 PM
I know this sounds lame but I can't even find the etc folder or the rc.wake/sleep files. Any help?
« How to install the original XP Bootloader? | Snow Leopard Ethics »
