windsynthaos windsynthaos is offline
Default Vmware Fusion, help SOLVED - 06-22-2009, 03:47 PM
Has anyone gotten this installed on a Mini 9?
When I try to install, it goes well until the indicator shows around 1 minute left. Then the machine locks up.
After a power down, I can only boot into safe mode. Locks on blue screen, with normal boot.
After running the uninstall for Vmware, things are back to normal.
It's version 2.0.4 that I just downloaded from VMware today.
PS, I can fully install it in safe mode.
Well, I am still confused, and I am not sure how I fixed it,but I think I am OK now.
I installed it in safe mode with EFI1.1 and then I can reboot normally.
It may not work with DellEFI1.2a5, which is what I started with.
« Help!! | Loosing space »
