emajy emajy is offline
Default Re: VGA output - 11-20-2008, 03:03 AM
Thanks for the information on the output resolutions. Guess its time to place an order.
Black Dell Mini 9 w/ A05 BIOS
Runcore 32gb SSD, 2GB RAM,
1.3MP camera and Bluetooth
running OS X Leopard 10.5.8 w/ NBI 0.8.3
2 finger scrolling and tethering to my Palm Pre
kancept kancept is offline
Send a message via ICQ to kancept Send a message via AIM to kancept Send a message via Yahoo to kancept
Default Re: VGA output - 12-02-2008, 05:48 AM
Just a heads up on the presentation front- I just took an IrDA port from a MBP and wired it up to USB and it works flawlessly for keynote and front row. I'm digging my soldering iron out to affix it permanently inside the Mini9. There's PLENTY of space for it in the monitor. Small hole, put in the IR panel from the MBP and tada!
I use a Dell Mini9 with OS X, 2GB RAM, 16GB SSD, 802.11n Airport card, and IrDA.
My IrDA Mod...
etiger13 etiger13 is offline
Default 05-29-2009, 11:11 PM
Got myself into a slight pickle and could use some help. I hooked up my Ferrari monitor (Acer F22) to my mini and picked clone display to try to output to just my 22" monitor and now everything is foo-bar'ed when i plug in the Acer. How can I not clone displays when it is plugged in? The Acer options box does not show unless it is plugged in.
« SHIFT key doesn't work | Mini 10 and Mac OSX install error »
