Default 09-21-2009, 01:59 AM
I had the static issue on 10.5, upgraded to Snow Leopard using VoodooHDA audio and I haven't had a static problem yet.
SkyWriter's Avatar
Default 09-21-2009, 12:11 PM
great! now there are two solution to the problem.
Default 09-24-2009, 12:29 AM
Fwiw the static noise issue on mine appears to be something to do with the headphone jack.
If I apply pressure around it on the top or bottom of the Mini 9 or fiddle with the jack itself the noise becomes quieter or silent. As such I believe it's something to do with a component being susceptible to heat (it only occurs on mine when the unit's been on for a while) and the offending component contacting the chassis or another component causing static.
That's my experience anyway.
EDIT: 10.5.6 / Chameleon 2.0RC2 / 8Gb STEC SSD
  (#14) Old
SkyWriter's Avatar
Default 09-24-2009, 12:55 AM
no different from a large number of observations.
if the following two conditions are true then you've got what others complain of:
1) if you can suspend it and the noise is gone when you resume.
2) on restart or reboot the noise will return.
then that's your fix.
the pushing, pressing squeezing, and blowing on things is a red herring. you're just changing conditions under which the noise is generated. you're not actually affecting the source of the noise.
  (#15) Old
SkyWriter's Avatar
Default 10-31-2009, 11:57 AM
in case nobody has noticed, with 10.5.8 (still using dellefi 1.2a5) the audio static is completely gone. well on my machine at least.
« External DVD Burner recommendation for OS X | NetbookInstaller3 - how do I get dual booting action with a Retail MacOSX and WinXP? »
