vdub6127 vdub6127 is offline
Default Safari 4 "tabs on top" possible fix - 06-13-2009, 11:23 PM
I'm still running the beta Safari 4 because of the screen real estate I save with the tabs being on top in the title bar. The production released version puts the tabs back below the URL bar, which is not as good for the limited netbook screen size.
Googling around, I found a possible fix that might work. Supposedly this worked in the beta to set the tabs to the bottom, which I assume might work the other way around. Anyone want to give it a try?
Open terminal and run:
defaults write DebugSafari4TabBarIsOnTop -bool TRUE
Restart Safari 4
(I would try it myself, but I dont want to upgrade if this doesnt work since I dont have the files to revert back.)
By the way, Safari 4 is much faster than Firefox on netbooks. It does Hulu and streaming flash smoothly as well. I've been on firefox forever but this made me make the switch. It's just as snappy as running Firefox on a much faster machine.
hutchyx hutchyx is offline
Default 06-13-2009, 11:29 PM
doesn't appear to work
Hilbe Hilbe is offline
Default 06-14-2009, 01:24 AM
All the Debug* Safari 4 hidden preferences were removed with the final release. It will not work...
« Quick Question about OSX Install Method 1 | Installing OSX from a desktop to a mini 9 »
