Send a message via AIM to jfrank
Default Need "N" wireless card for 9 running OS X - 06-12-2009, 02:03 AM
What is the best wireless "N" card that has support for OS X? I have hard that none of the Intel cards work and the Apple wireless card is too hot to handle. So what about the Dell 1505? what is the difference between that and all the others? I need help with what card to buy.
Thanks
somms's Avatar
Default 06-12-2009, 02:10 AM
Thanks
802.11n upgrade heat issue
Some AirPort Extreme WLAN on Ebay have been reported to be fakes and may run hotter then the Dell Wireless 1505 which is fully OSX compatible...
Default 06-12-2009, 02:14 AM
I'm debating what to do about that as well... it's part of the risk with buying things over eBay that are "parts", whether it's the Apple card or the Dell card, you just don't know if it's real or not. And of course the seller will say if it works then you got what you ordered.
somms's Avatar
Default 06-12-2009, 02:17 AM
Dell : Dell 2.4/5 GHz Wireless 1505 PCI Express WLAN Mini-Card for Select Dell Systems : Wireless/WiFi : Home & Home Office
FWIW: The Dell Wireless 1505 is expensive via Dell but wouldn't risk being a 'fake' either...
Default 06-12-2009, 02:27 AM
Thanks for the link. Do you know whether a real (I imagine you can get them from an Apple authorized reseller) Airport Extreme card will still run hot, or whether it's solely a result of substandard illegal manufacture?
Default 06-12-2009, 03:27 AM
Just get a used Dell 1505 on eBay.
Send a message via MSN to TallPaul86
Default 01-14-2010, 11:20 PM
Hi Folks
Apologies for hi-jacking another thread however just to clarify, will the below link (from Dell UK site) work on my UK DM9? It has OS X 10.5.6 on it
DELL Dell - 1505 - Wireless Card - 802.11a/g/n - Mini card - European - Kit : Networking | Dell United Kingdom
Should be OK despite not listing the Inspiron 910 on the Compatibility chart
aaron580's Avatar
Default 01-15-2010, 01:54 PM
Ive got a 1500 Draft N in mine thats 25$ on ebay and it works 100% flawless.
17 inch MBP - 2.5ghz, 4 gig ram, 250gig 7200rpm HDD, Nvidia 8600 512mb overclocked!!!, Snow Leo/Windows 7 ultimate
Dell Mini 10v - 2 gig ram/120gig hdd/Snow Leo/Looking into a touchscreen mod (still)
Dell Mini 9 - 2 gig ram/32 gig STEC/Windows 7 Pro/Snow Leo/Dell 1500 N wireless/what will become of this little lappy....?
« HTC Touch Diamond as Modem for 10v | Updating an older USB Install image? »
