thedankone thedankone is offline
Default Restart Issues Help Needed - 06-09-2009, 03:09 AM
My restart is spotty at best...lots of the time it just quicks to a black screen and stays on. This has cost me some time...installed some updates then it didn't restart had a kernel panic at boot had to reinstall. Now I have a fresh install restart worked great now it is back to crap. Specs below:
Mini 9 os x 10.5.7 updated from retail 10.5.6 install
dell efi 1.1
a05 bios
2 gigs
16gig stec
webcam 1.3mp
usb legacy off
TheDoctah TheDoctah is offline
TheDoctah's Avatar
Default 06-09-2009, 03:13 AM
hey buddy...unfortunately you're sort of stuck in your options since you have bluetooth.
You will have to sacrifice something no matter what with your config. The bluetooth is the culprit.
Take a look at this Matrix to decide what you'd like best.
Cherry Red Dell Mini 9 | 2 GB RAM | 16 GB STEC SSD | 0.3 MP Webcam
BIOS A06 | 10.6.8
« DellMini9 +10.5.7 just freezes when I plug in external monitor | Disabled HD in Bios, Leopard still sees it »
