| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | MBR works just fine, I use it on my Mini. What options are you selecting in DellEFI? You need to make sure to check the option to reinstall the bootloader. Also, is this an upgrade or a clean install? If an upgrade, what version were you running before, and if it is clean, what instructions are you using to install with? http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#4)
(#5)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | First make sure that the partition is named OSXMINI9. Also try another install since it is not a perfect process and may glitch out every now and then. You may need to use safe mode in order to boot in, you may also need to use the USB drive in order to select the SSD for boot. http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#6)
| Junior Member Posts: 6 Join Date: Jun 2009 | Quote:
partition is named OSXMINI9 and I am on my fourth reinstall unfortunately. | |
(#7)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | Have you tried recreating the flash drive? I have had issues in the past and found that simply redoing the drive fixes the problem. http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#8)
(#9)
| Junior Member Posts: 6 Join Date: Jun 2009 | It turns out that the problem was with the chameleon boot loader. It kept on trying to install the software on the RDisk0s2 partition. Since I was running using an MBR instead of a GUID I did not have an RDisk0s2 partition, only RDisk0s1 partition. I repartitioned using GUID which created two partitions on the drive, reinstalled, and it was successfull. Mechdrew, thanks for taking the time to help and for all the great guides you have posted out there! |
