Default OS X on Mini 10v - Audio Issue / Question - 06-04-2009, 09:18 PM
I'm successfully dual booting Win7 and OS X on my new 10v thanks to the great guides here but I'm having a small issue within OS X, I hear system sounds in the audio but do not hear audio in iTunes or Quicktime. Any ideas?
OS X 10.5.7
DellEFI 1.2a5
Using audio driver from @anguish post - "Sound does work. Use this link: http://www.blackmonktech.com/NC10%20...ackage.pkg.zip Install it, reboot, should be golden."
anguish's Avatar
Default 06-05-2009, 01:52 AM
Not having any issues here. If you go under Systems Prefs -> Sounds, make sure everything is being outputted properly. I was just streaming a radio station from back home in iTunes without issue.
Default 06-05-2009, 04:57 PM
It was an output issue. Everything is now working perfectly. Thanks!
anguish's Avatar
Default 06-05-2009, 05:19 PM
You're welcome!
« Help! I Bricked my Dell Mini 9 OSX Install 10.5.7 | Win7 and OSX, no Mac...99% there »
