pmronline pmronline is offline
Smile Smart Scroll 3.0 - 05-27-2009, 07:03 AM
Just came across this in the apple site. Did anybody try installing the Smart Scroll 3.0 in dell mini's with osx?
Apple - Downloads - System/Disk Utilities - Smart Scroll
Latitude 2100 | BIOS A02 | 1024 x 600 | 2GB RAM |
160GB HD | WIN 7 | TOUCH SCREEN | 5100 AGN | Black
Mini 10V | BIOS A06 | 1024 X 600 | 1GB RAM | 160GB HD | MAC OSX 10.6.7
k123dave k123dave is offline
Default 05-27-2009, 01:06 PM
I use it and it works really well. I have a Logitech marble mouse, which doesn't have a scroll wheel, and I have it set up that when I press the 'down' button, it activates the trackball to scroll, which is very neat
Tentec Tentec is offline
Default 05-27-2009, 06:33 PM
Yeah, been using it foe about a week now, it works great. I think it is the icing on the cake for the track pad driver. it allows you to smooth scroll, similar to the iphone and it allows for inertia scrolling . would recommend it for anyone who's using the track pad drivers, particularly on side scroll.
patters patters is offline
Default 05-28-2009, 12:30 AM
Great find! The fact that the trackpad is so tiny is now almost irrelevant.
agianino agianino is offline
Default 05-28-2009, 05:43 AM
I use it too and have been very happy with it. It really does put the icing on the cake when combined with the touchpad drivers. Give it a whirl, you will be happy you did.
smart scroll
« Cannot connect to Bluetooth PAN in some cases for tethering | MONOLINGUAL Question ? ? ? »
