EricsVostro EricsVostro is offline
Default DVD drives that are compatible with Mini 9 or Vostro a90 running OS X - 05-23-2009, 09:28 PM
I'd like to get an external DVD driver that will work to both install OS X 10.5.6 and use after OS X is installed.
Thanks in advance for any help, suggests and advice.
Default 05-23-2009, 10:21 PM
XBOX 360 HDDVD drive works great, and it is cheap, as the HD format is no longer being produced. OS X install went well, and it works with the finished install, it's just not what you would call "slim" or "ultra-portable."
Functioning Hibernation
« Triple Boot: XP, OSX, & Ubuntu 9.04 Remix | Stuck at white loading screen »
