  (#341) Old
Send a message via AIM to damengual
Default 08-29-2009, 08:31 PM
Originally Posted by damengual View Post
Not Booting after post 10.5.7 DellEFI
I had everything going smooth, ran DellEFI again in safe mode after the 10.5.7 update, now all i get is the Apple boot screen with an endlessly spinning circle.
can't boot into any other modes.
fixed using netbookboot instead of dell efi. i highly reccomend it. thanks drew for having a very useful site!
Macbook Pro 15" | OSX10.5.8/Win XP sp2 | 2.4Ghz Core 2 Duo | 4GB DDR2 | 500GB Toshiba HD
Dell Mini 9 | OS X 10.5.8 | NetBookBootMaker 0.8.2 RC2 | BIOS AO4 | 64 GB SuperTalent | 2 GB Ram
  (#342) Old
mechdrew's Avatar
Default 08-29-2009, 10:06 PM
Originally Posted by treeswithteeth View Post
2 days without my hackintosh and spirits are low. Somehow my system wasn't being recognized as having an intel processor (which it used to) so I decided to tinker with the delefi util to fix it. Well, not sure exactly what I did but I hosed something and now OSX hangs on boot (circle just keeps spinning). I've tried a bunch of stuff but chameleon seems to be hanging me up because I have dual boot setup (OSX/Ubuntu). I can't get it to boot into safe mode or anything. I tried recreating my setup/boot disks so I could boot with a usb drive to run the delefi util but even that doesn't want to cooperate. I go through the steps and get stuck on the bootmaker which starts then automatically terminates before giving me any options. Any ideas would be much appreciated. If I could just get into safe mode I think I'd be all set. Thanks in advance.
Switch to NetbookBootMaker (instead of DellEFIBootMaker) and then boot into the Mac OS X Installer. Under the Utilities menu you will find NetbookInstaller..., use that to reinstall the bootloader on your machine. Link in signature.
  (#343) Old
mechdrew's Avatar
Default 08-29-2009, 10:08 PM
Originally Posted by griffter47 View Post
Hi there,
First of all, many thanks for the guide, its been a great help
I've installed leopard on two mini 9's with the exact same specification, but sometimes they will freeze up, then after a forced restart, the commandline comes up with 'no operating system found'. I then go through the install process again and when I go into disk utility, the partition has disappeared. They both have 32gb Crucial SSDs.
Is this to be expected or are the SSDs faulty? How can I prevent this.
-t
No idea. I've never heard of a disappearing partition, and I can't vouch for the validity of Crucial SSDs. Sorry.
  (#344) Old
mechdrew's Avatar
Default 08-29-2009, 10:09 PM
Originally Posted by Faloopa View Post
I think I'm going to try tomorrow: has anyone tried yet? Does the DellEFI patch work with 10.6?
I'm using a Vostro A90 with the stock 16GB SSD, 1GB RAM (for now - I'm going to order the 2GB upgrade this weekend), and BIOS A04. I'm running 10.5.6 right now with no problems, but I wonder what 10.6 will do?
I'm definately going to do a full TM backup first in case I have to go back to Leopard, but does anyone have any tips?
Thanks!
The only advice I can give you is to look at the Snow Leopard subforum, they have many threads there for installing Snow Leopard, but it's not easy at the moment. I will be checking into SL once I get my Windows-only install guide finished.
  (#345) Old
Default Monitor mirroring? - 09-01-2009, 06:33 AM
Like an idiot I accidentally turned on Mirroring for the second monitor on my Vostro A90 - dumb! - and now I can't fit it. I know that I can reset the PRAM/NVRAM by holding option+command+P+R during start up on my iMac but it doesn't work on my mini.
Anyone else make this mistake......and fix it? Is there a Terminal command to reset the NVRAM or at least reset the monitor settings to stock? Or (even better) a way to get mirroring to work on the Dells?
I wouldn't even do this if I didn't need to run a ProPresenter show and I'd really like to use my Mini instead of lugging my iMac all across town.
Dang - do I need to reinstall OS X.......again?
Vostro A90, 1GB RAM, stock 16GB SSD, BIOS A04, OS X 10.5.6
********UPDATE 9/1***********
Nevermind the above: I got it. Through a little research I found that Hackintosh's don't USE NVRAM so you can't reset it. I fixed the monitor problem by using the Mirror Displays app (http://www.fabiancanas.com/Projects/MirrorDisplays/) - it took me a bit but I figured out that I had to position my cursor over the app icon, plug in the second monitor (screwing up the picture on both) and then blindly double click. Now Extended Desktop - and ProPresenter - work great.
I think tomorrow I'm going to do a clean install anyway using the NetbookBootMaker so I can run 10.5.8 easily.
Thanks!
  (#346) Old
Default 09-03-2009, 04:23 AM
When I try to choose my USB key with the iso file (using http://osx.mechdrew.com/guides/oldguide.shtml with Windows only) I get a kernel panic error. How can I begin to figure out what is going wrong?
using 10.5.7 with miniboot123v8.02b1
Just a bit more detail - I can get into the bootloader, up the step where I choose 81 for the USB Key, and then it happens.
If I choose to just boot straight to the USB key it says
boot0:testing
boot0:error
in case that helps.
  (#347) Old
Default 09-12-2009, 05:14 AM
I using a dell mini 9, I used the 10.5.6 CDs to install OS X and it is running pretty slow and will not create the dsdt.aml file with dellefi1. Any idea what this could be? I am using dellEFI1.2A5
EDIT: Ok I got it to install but its still running kind of slow. Any idea what the problem could be?
  (#348) Old
Smile noob update Question OSX 10.5.8 - 09-17-2009, 04:25 PM
Hi
I just created my DellMini 9 Mac.
The creation went very well and I am very please with it
One small issue: I just updated my OS to 10.5.8 using the "software update" utility. Now I have no audio. I think I had audio in 10.5.7 but can't prove it.
Am I suppose to reinstall the DellEFI after each update or what do I need to do here? If so where in the Guide V3 do I start?
Sorry to ask here but I just signed up for the forum and can not figure out how to create an original post.
Thanks
Oak
  (#349) Old
Default 09-19-2009, 10:54 PM
DEllEFI is outdated/buggy
use Netbookinstaller.
find tutorials/files here:
OS X | mechdrew
Originally Posted by OakMan View Post
Hi
Thanks
Oak
  (#350) Old
Default 09-27-2009, 09:53 PM
Hi
Thanks
Oak
Try reinstalling os 10.5.8 combo pkg.
« VostroA90 w/Runcore SSD Upgrade | Dell 14z »
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/8092-dellefi-guide-v3-outdated-use-netbookinstaller.html
Posted By For Type Date
Frankenbook! Another look at hacked Mac netbooks - Macworld Forums - Page 4 This thread Refback 08-29-2009 01:51 PM
Frankenbook! Another look at hacked Mac netbooks - Macworld Forums - Page 3.9333333333333 This thread Refback 08-28-2009 06:50 PM
Frankenbook! Another look at hacked Mac netbooks - Macworld Forums - Page 3 This thread Refback 08-24-2009 11:49 PM
rexroof's hackintosh Bookmarks on Delicious This thread Refback 08-23-2009 02:32 PM
Macworld: Frankenbook! Another look at hacked Mac ... This thread Refback 08-12-2009 10:16 PM
Macworld: Frankenbook! Another look at hacked Mac ... This thread Refback 08-12-2009 06:49 PM
Macworld: Frankenbook! Another look at hacked Mac ... This thread Refback 08-12-2009 06:01 PM
Macworld: Frankenbook! Another look at hacked Mac ... This thread Refback 08-12-2009 04:09 PM
Contact | DellEFI | mechdrew This thread Refback 07-18-2009 05:40 PM
How-To: Install Mac OS X - DellEFI Method - MyDellMini This thread Refback 06-10-2009 07:07 PM
Legality | DellEFI | mechdrew This thread Refback 06-09-2009 10:26 AM
A Guided Tour oo DellEFI 1.2a5 | DellEFI | mechdrew This thread Refback 06-03-2009 11:31 PM
How-To: Install Mac OS X - DellEFI Method - MyDellMini This thread Refback 06-03-2009 07:44 PM
Guide Old Method 4 | DellEFI | mechdrew This thread Refback 05-26-2009 01:16 PM
Guide Old Method 2 | DellEFI | mechdrew This thread Refback 05-25-2009 05:33 PM
Guide Change Log | DellEFI | mechdrew This thread Refback 05-23-2009 07:25 PM
Guide Old Method 1 | DellEFI | mechdrew This thread Refback 05-20-2009 03:10 PM
Old Guide | DellEFI | mechdrew This thread Refback 05-19-2009 08:54 PM
Guide Intro 3 | DellEFI | mechdrew This thread Refback 05-19-2009 06:52 AM
Guide Advanced 1 | DellEFI | mechdrew This thread Refback 05-19-2009 01:21 AM
Guide Method 4 | DellEFI | mechdrew This thread Refback 05-18-2009 09:03 PM
Guide Advanced 2 | DellEFI | mechdrew This thread Refback 05-18-2009 07:55 PM
Guide Method 2 | DellEFI | mechdrew This thread Refback 05-18-2009 02:16 PM
Guide Intro 1 | DellEFI | mechdrew This thread Refback 05-18-2009 05:34 AM
Guide Advanced 3 | DellEFI | mechdrew This thread Refback 05-18-2009 03:16 AM
Guide Method 3 | DellEFI | mechdrew This thread Refback 05-18-2009 02:03 AM
Guide Intro 2 | DellEFI | mechdrew This thread Refback 05-18-2009 01:48 AM
Guide Tip 3 | DellEFI | mechdrew This thread Refback 05-18-2009 12:42 AM
Guide Tip 1 | DellEFI | mechdrew This thread Refback 05-17-2009 11:43 PM
Guide Method 1 - Single USB Drive (Mac-only) | DellEFI | mechdrew This thread Refback 05-17-2009 10:42 PM
DellEFI | mechdrew This thread Refback 05-17-2009 09:17 PM
Downloads | DellEFI | mechdrew This thread Refback 05-17-2009 08:59 PM
Guide | DellEFI | mechdrew This thread Refback 05-17-2009 08:57 PM
DellEFI Blog | mechdrew This thread Refback 05-17-2009 11:03 AM
