(#181)
(#182)
(#183)
(#184)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | TALA, I just want to make sure on this. When you try to load the Mac OS X Installer, whether via DellEFIBootMaker or DellMiniBoot, it crashes? I would redo the DellEFIBootMaker drive for starters. I think there is an incompatibility between DellMiniBoot and DellEFIBootMaker, so if you try the DellMiniBoot route again do it only after you have reformatted the OSXDVD drive, and only copy the DVD files, do not run DellEFIBootMaker. http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#185)
(#186)
| Junior Member Posts: 5 Join Date: May 2009 | I’m new here, but I’ve gotten my mini9 to accept leopard - thanks you all for sharing all these wonderful apps and tips. One thing: the key to reinstall or updates (to 1.5.7 etc) is to be able to “hack bless” the sdd again. I’m going crazy each time I need to do that, as I don’t understand how to get to dellefi: if I use the dvd image there is no way for me to get to dellefi, same thing from the type 11 partition (at least I can’t! =-D I’m sure you wizards could do that while reading the morning paper!). And if I’ve just updated the system for example.... Well, the update asked for a restart - then and only then - actually install, making me unable to get to dellefi as.... The system wont boot! This is actually making me dizzy! Could someone explain in 4 years old terms, or even better: could someone create a script or something, so that we could plug the type 11 in, boot on it, type “blessthisdiskOHdellefi“ and boom, it would be done! Again many thanks for all the hard work!!! |
(#187)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | Quote:
I suggest reading the guide and then coming back to ask questions. http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter | |
(#188)
| Member Posts: 34 Join Date: Jun 2009 | first thanks for making the guide how to make customs OSX installer, with that I manage to squeeze 10.5.6 on my 8gb SSD, and install was successfull. but have some few issue. EDIT: sound issues fixed after upgrade to 10.5.7! My mini 9 8gb SSD, 1GB RAM running OSX 10.5.7 with 1.3GB space left ![]() Thanks for providing a great guide! |
(#189)
| Member Posts: 52 Join Date: Mar 2009 | Quote:
As the ancient greeks use to say " may the gods be praised" I did as you suggested and now I have a machine that is fully functional--I just redid evrEything as you suggested-only hang up was step 10 of your guide, but I kept repeating it and now Mt. OLYMPUS is happy--you guys out there follow mechdrew's guide to the letter--Thanks !!!! | |
(#190)
| Member Posts: 40 Join Date: May 2009 | Quote:
I may be over thinking this, but I want to clarify the step-by-step as I find myself gun shy and concerned about screwing up the upgrade and not being able to access my system. 1- While booted into OS X, I run DellEFI 1.2a5 under which I delete the dsdt.aml (Following some process from the original install instructions?) 2 - Shut down the system 3 - Remove the 1GB memory stick and replace it with the new 2GB memory stick 4 - Reboot the system into OS X 5 - Rerun DellEFI and it regenerates a new dsdt.aml file (Following some process from the original install instructions?) Thanks and sorry for being so thick ![]() My first "Mac" after 20 years on Windows and loving it | |
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/8092-dellefi-guide-v3-outdated-use-netbookinstaller.html | ||||
| Frankenbook! Another look at hacked Mac netbooks - Macworld Forums - Page 4 | This thread | Refback | 08-29-2009 01:51 PM | |
| Frankenbook! Another look at hacked Mac netbooks - Macworld Forums - Page 3.9333333333333 | This thread | Refback | 08-28-2009 06:50 PM | |
| Frankenbook! Another look at hacked Mac netbooks - Macworld Forums - Page 3 | This thread | Refback | 08-24-2009 11:49 PM | |
| rexroof's hackintosh Bookmarks on Delicious | This thread | Refback | 08-23-2009 02:32 PM | |
| Macworld: Frankenbook! Another look at hacked Mac ... | This thread | Refback | 08-12-2009 10:16 PM | |
| Macworld: Frankenbook! Another look at hacked Mac ... | This thread | Refback | 08-12-2009 06:49 PM | |
| Macworld: Frankenbook! Another look at hacked Mac ... | This thread | Refback | 08-12-2009 06:01 PM | |
| Macworld: Frankenbook! Another look at hacked Mac ... | This thread | Refback | 08-12-2009 04:09 PM | |
| Contact | DellEFI | mechdrew | This thread | Refback | 07-18-2009 05:40 PM | |
| How-To: Install Mac OS X - DellEFI Method - MyDellMini | This thread | Refback | 06-10-2009 07:07 PM | |
| Legality | DellEFI | mechdrew | This thread | Refback | 06-09-2009 10:26 AM | |
| A Guided Tour oo DellEFI 1.2a5 | DellEFI | mechdrew | This thread | Refback | 06-03-2009 11:31 PM | |
| How-To: Install Mac OS X - DellEFI Method - MyDellMini | This thread | Refback | 06-03-2009 07:44 PM | |
| Guide Old Method 4 | DellEFI | mechdrew | This thread | Refback | 05-26-2009 01:16 PM | |
| Guide Old Method 2 | DellEFI | mechdrew | This thread | Refback | 05-25-2009 05:33 PM | |
| Guide Change Log | DellEFI | mechdrew | This thread | Refback | 05-23-2009 07:25 PM | |
| Guide Old Method 1 | DellEFI | mechdrew | This thread | Refback | 05-20-2009 03:10 PM | |
| Old Guide | DellEFI | mechdrew | This thread | Refback | 05-19-2009 08:54 PM | |
| Guide Intro 3 | DellEFI | mechdrew | This thread | Refback | 05-19-2009 06:52 AM | |
| Guide Advanced 1 | DellEFI | mechdrew | This thread | Refback | 05-19-2009 01:21 AM | |
| Guide Method 4 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 09:03 PM | |
| Guide Advanced 2 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 07:55 PM | |
| Guide Method 2 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 02:16 PM | |
| Guide Intro 1 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 05:34 AM | |
| Guide Advanced 3 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 03:16 AM | |
| Guide Method 3 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 02:03 AM | |
| Guide Intro 2 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 01:48 AM | |
| Guide Tip 3 | DellEFI | mechdrew | This thread | Refback | 05-18-2009 12:42 AM | |
| Guide Tip 1 | DellEFI | mechdrew | This thread | Refback | 05-17-2009 11:43 PM | |
| Guide Method 1 - Single USB Drive (Mac-only) | DellEFI | mechdrew | This thread | Refback | 05-17-2009 10:42 PM | |
| DellEFI | mechdrew | This thread | Refback | 05-17-2009 09:17 PM | |
| Downloads | DellEFI | mechdrew | This thread | Refback | 05-17-2009 08:59 PM | |
| Guide | DellEFI | mechdrew | This thread | Refback | 05-17-2009 08:57 PM | |
| DellEFI Blog | mechdrew | This thread | Refback | 05-17-2009 11:03 AM | |
