(#21)
(#22)
(#23)
(#24)
| Junior Member Posts: 18 Join Date: Apr 2009 | I had been puzzling about my battery performance too, and it seems like disabling bluetooth did the trick and well over doubled my battery life from 2 hours to 4.5 hours. It's really surprising that bluetooth can make such an impact. My guess is that when you have a paired bluetooth device, the OS keeps polling for it, which is a major drain on the battery. The procedure for fixing bluetooth disabling is described here: http://www.mydellmini.com/forum/mac-...minal-mod.html |
(#25)
(#26)
| Senior Member Posts: 151 Join Date: Apr 2009 | rbrtrx was correct. When OSX BT driver is in discoverable mode, it uses some battery power. I tried to turn BT off on 10.5.7, but the option was missing. I have now patched "IOBluetoothFamily.kext" with the correct vendor and product IDs for our Dell's BT module. The option to turn off BT from the menu bar is available now. You should check out the Bluetooth Terminal Mod thread on how to do it. |
(#27)
| Junior Member Posts: 19 Join Date: Apr 2009 | I am getting barely 2 hours on my Dell Mini 9 Hackintosh 10.5.7. I don't see any visible change from the previous version. I looked at my power settings, and everything appears to be correct for more battery life, but I am still only getting about 2 hours (according to the battery indicator). What are some tips to improve this? I would be happy to get 3 hours, let alone the extended hours so people have been reporting. I am also considering getting an 8-cell battery, but holding off due to some compatibility issues I heard about. UPDATE: I ran DellEFI1.1 again, and now getting about 2.5 hours, so a bit of an improvement. The odd things is that the battery indicator has gone up a bit while the computer is using the battery. That's strange. I have a feeling that this indicator is off. Any ideas? Should I run DellEFI1.1 again?? - MacBook 13 White | 4GB RAM | 120GB HD | OSX 10.5.6 - Dell Mini 9 Mac OS X | 2GB RAM | 64GB SSD | BT | 1.3MP Cam | OSX 10.5.7 | USB Legacy Mode off |
(#28)
(#29)
| Junior Member Posts: 9 Join Date: May 2009 | Quote:
(#30)
| Senior Member Posts: 194 Join Date: Feb 2009 Location: Brampton, ON | Quote:
Bluetooth is definitely a culprit with battery life especially when left on permanently. If turning off Bluetooth doesn't resolve your battery life, you may have a corrupt dsdt.aml after the upgrade. Remove the existing one, reboot, then let DellEFI regenerate a new one. BIOS A06 | DellEFI 1.2a5 | 10.5.8 | Windows XP SP3 | |
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/7901-10-5-7-battery-life.html | ||||
| Hackintosh Mini 9: A bit better than a late G4 - im addicted | This thread | Pingback | 05-27-2009 01:31 PM | |
| NY Apple Products Examiner: Mac OS X 10.5.7 - Boosting Hackintosh Batteries | This thread | Refback | 05-21-2009 11:51 PM | |
