lantzn lantzn is offline
lantzn's Avatar
Default PLEASE Help - Hibernation Message - 05-13-2009, 02:21 PM
Could someone please explain what is causing this with some installations? Also how to fix it. Thank you.
Hibernation message
chazzek chazzek is offline
chazzek's Avatar
Send a message via AIM to chazzek
Default 05-13-2009, 06:39 PM
If there's a hibernate file on the drive, it'll always try to resume from that. But hibernate doesn't work on the Mini. To remove the message and save a few gigs on your drive, do the following at a terminal:
sudo pmset hibernatemode 0
sudo rm -f /var/vm/sleepimage
Dell Mini 9 | Mac OS X 10.6.2 | 2 Jigabytes RAM | 32 Jigabyte STEC SSD | Bios A05
NetbookInstaller 0.8.3 | USB Legacy Mode off | No camera
MINIRUN47 MINIRUN47 is offline
Default 05-14-2009, 03:19 AM
Thanks guy's both of the above posters do awesome work, now the only time i've seen this message is after doing my install to my runcore i wanted to see if i did it right so i swapped out my stock ssd and put in the runcore and it booted fine (here is what i did not do) i did not run the dellefi because it was just a test to see if i did it right. So im still waiting for the ice blue mini to get here to be complete and if i do get this message i'll do what chazz suggested, THANK'S....
Ice Blue 32gb ssd 2gb ram OSX .3mp camera....
Maxime Maxime is offline
Default 05-18-2009, 07:50 PM
Hibernation message
I "fixed" the problem by running DellEFI again and removing the Hibernate.
Dell Mini 9 / Atom 1.6GHz / 2GB / RunCore 32GB SSD / OSX 10.6.0
Mac Mini C2D 2.0GHz / 4GB / G.Skill Falcon 64GB SSD / OSX 10.5.8
robgarth robgarth is offline
Default Permanantly stop sleepimage - 05-21-2009, 09:43 AM
I have found that these methods don't completely stop the creation of a RAM sized sleepimage file. I am not sure if it is all the time but I have the file recreated on shutdown sometimes.
To stop it happening completely set the sleepimage file to /dev/null
$ sudo pmset hibernatefile /dev/null
Even if the system tries to create the file now it will be written to nowhere.
« Dock resizing by itself? | What is your score? - GEEKBENCH cpu test »
