Inquieto Inquieto is offline
Default Bluetooth is not installed - 05-12-2009, 03:29 PM
I've installed the operative system without problems,everything work (Screen, audio, Wi-Fi) but the bluetooth still not being recognized by the system. In the BIOS is still active, but there's no way to make the BT card visible to the OS. Any help?
BeyondtheTech BeyondtheTech is offline
BeyondtheTech's Avatar
Send a message via AIM to BeyondtheTech Send a message via MSN to BeyondtheTech Send a message via Yahoo to BeyondtheTech
Default 05-12-2009, 03:45 PM
Rerun the DellEFI and make sure "Fix Bluebooth" is checked. Fixed my issue when my Bluetooth shut off permanently after a bad pairing.
Black Mini 9 2GB 64GB BT 2.1 1.3MP 802.11g XP SP3 OSX 10.5.7 DellEFI 1.1 MBR A05
Read my guide on How to Dual-boot OS X and Windows from the DellEFI Method!
Default 05-12-2009, 04:26 PM
I've tried several times to Rerun the DellEFI with the "Fix Bluetooth" checked, without solution...and also following the instructions in this topic without any emprovement...what's wrong?
mfruit mfruit is offline
Default 05-12-2009, 06:48 PM
Are you sure that BlueTooth is active? This is from the OS, not BIOS.
If not, boot into Windows or Ubuntu and activate it first before dropping back into OSX. BT wouldn't work for me under OSX until I did that.
bluetooth, not installed, not recognized, problems
« help for this setup: osx on ssd | win 7 on usb hdd | Some help with my OSX usb drive (Sandisk Cruzer) »
