hedwig hedwig is offline
Default Is iLife part of the Retail DVD? - 05-08-2009, 07:20 PM
Hi, Is iLife (want to use Garage Band) included in the Retail DVD install? thanks
bmcclure937's Avatar
Default Re: Is iLife part of the Retail DVD? - 05-08-2009, 07:28 PM
Nope... sorry
iLife does not come as a part of OSX Leopard (or any version of OSX)... although iLife is included when you purchase a new Mac. This does cause some confusion because people then perceive that iLife was a part of OSX when, in reality, it is not
Meklort's Blog | NBI Google Code Page | -- the best OSX installation guides
Nethfel Nethfel is offline
Default Re: Is iLife part of the Retail DVD? - 05-08-2009, 07:30 PM
The normal retail DVD does not include iLife. iLife is bundled with new Apple computers on their gray install dvds, which aren't compatible with systems other then the system they were meant for (ie: you couldn't take a gray imac cd and use it on a macbook).
You can get a bundle pack though that has ilife, iwork and leopard for about the cost of leopard + iwork so that might be an option you may be interested in.
SkyWriter SkyWriter is offline
SkyWriter's Avatar
Default Re: Is iLife part of the Retail DVD? - 05-08-2009, 07:31 PM
get the iLife, iWork, OSX bundle. you get three awesome products for less than the cost of any two
Problems with external displays or projectors in OS X? Try MirrorDisplays2!
Got Static?
lantzn lantzn is offline
lantzn's Avatar
Default Re: Is iLife part of the Retail DVD? - 05-08-2009, 10:12 PM
Yes the bundle is called the "Mac Box set".
Apple Store $169
Apple Government Price $140
« Sleep Resume | Is it safe to apply all Software Updates (type11 10.5.6)? »
