Default Desktop not locked after restart? - 04-28-2009, 04:12 PM
When I first boot into Leopard I have to login with my username and password, but when I wake my Mini from sleep is does not prompt for a username and password...any ideas?
meklort's Avatar
Default Re: Desktop not locked after restart? - 04-28-2009, 04:14 PM
System Preferences -> Security -> General
It's the first checkbox.
Default Re: Desktop not locked after restart? - 04-28-2009, 05:14 PM
I made sure I checked that and still not locking...
meklort's Avatar
Default Re: Desktop not locked after restart? - 04-28-2009, 07:11 PM
That's strange. On my mini (and macbook) checking it makes it locked when you wake up the computer.
I'm not sure what the problem is then.
Default Re: Desktop not locked after restart? - 04-28-2009, 11:22 PM
I know my Aluminum MacBook locks after sleep everytime...I will play with check on and off the setting and see if something changes.
« Startup occasionally gets stuck on gray Apple icon screen. | Moved from 10.5.6 to win7 »
