| Junior Member Posts: 5 Join Date: Apr 2009 | This is what I did to get it to work perfectly. how-to-dellefi-1-1-10-5-6-for-noobs-using-external-drive-p55212.html Then install Meklorts mouse pad drivers here: touchpad-drivers-t5577.html Be sure you save the page to a text file to paste all of the commands, it's a lot of terminal stuff to retype. Everything works though. Mouse, keyboard, lan, wifi, sound, mic, all the sound jacks, sleeps, wakes from sleep perfect and shuts down perfect. The battery meter is spot on and quartz extreme is supported. Be sure you debloat the sucker after with xslimmer or monolingual ( i think those are the names). |
