(#41)
(#42)
(#43)
| Guru Posts: 1,353 Join Date: Feb 2009 Location: Colorado, USA | Yes, 10.6 will work fine. There may be a few issues with kexts, but It's very possibly to get everything working. Dell Mini 10v | Mac OS X 10.6.5 | 1 GB RAM | 160 GB HDD | BIOS A06 My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a Lockerz.com invite? message me. |
(#44)
(#45)
(#46)
| Member Posts: 43 Join Date: Jul 2009 | I might be able to get my hands on this build. I'll make an image of my HDD first incase everything goes to pot (I love the Runcore USB interface) and then either try a remote install using remote CD, or put the disk image on a USB stick Contributor to the NetbookInstaller project |
(#47)
| Member Posts: 43 Join Date: Jul 2009 | updating over my current hackintosh install failed with a KP on boot no matter what (tried installing disabler dsmost, and other recommendations from netkas.org, replaced the SSD kext from 10.5.8) so I'm going to do an install akin to what meklort suggested and report back ![]() Contributor to the NetbookInstaller project |
(#48)
(#49)
| Member Posts: 43 Join Date: Jul 2009 | yes. I'm only doing clean installs. I think I just need to find the right combo of kexts. Just sorting it out now, but installation takes 30 mins each time, so every time i screw it up It takes another 30 mins! (only screwed up once so far) Contributor to the NetbookInstaller project |
(#50)
| Member Posts: 43 Join Date: Jul 2009 | no luck so far, getting kernel panics at the apple logo no matter what I try. Would great If I could work out what was causing them! (Anyone?) Contributor to the NetbookInstaller project |
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/700-will-osx-10-6-snow-leopard-run-mini.html | ||||
| Dell Mini 9 users : Please advise on Snow Leopard installation and operation | This thread | Refback | 08-27-2009 01:35 PM | |
| Guide: Snow Leopard on PC 10a432(GOLD MASTER!!!) | TeknoJunkie | This thread | Refback | 08-14-2009 07:08 PM | |
