  (#111) Old
Default Hi Carlos!! - 09-01-2009, 11:32 PM
Sorry, in mini 9
Gray Screen with chameleon rc640, but throught Usb boot correctly
  (#112) Old
Default 09-02-2009, 03:29 AM
Originally Posted by denisodisea View Post
Sorry, in mini 9
Did you put the com.apple.Boot.plist with gma 950 efi string in it, otherwise it stays at a blank grey screen. You can replace the original or place it in /Extra.
Dell Mini 10v: Obsidian Black, 1GB DDR2 533MHz Ram, 1.6GHz Intel Atom, 120GB FUJITSU HDD, 6-Cell, Mac OS X Snow Leopard 10.6.3 Build 10D573 booted with Chameleon 2 RC5 pre6, Dell Wireless 1397 flashed! (Everything working, now featuring sleep when closing lid!)
  (#113) Old
Default 09-02-2009, 12:27 PM
Originally Posted by fluoro View Post
I choose to not transfer and clic on the Continue button, the button simply turns gray and notingh happens. After a while the cursor shows the coloured spinning wheel but nothing happens, it simply stays on the Migration Assistant box. I tryed to wait up to 1 hour or so but nothing. Later I tried to choose the other options but everytime the setup process stop at this point.
the same issue by my mini 10v. is there any solution and this problem is solved?
thanks a lot
  (#114) Old
Default 09-02-2009, 12:56 PM
thanks a lot
The solution is somwhere in the post, you have to boot into singel mode (-s) and finish the setup manually.
Viel Glueck
  (#115) Old
Default 09-02-2009, 12:59 PM
hi nautiker,
thanks, i will try it.
Viel Glueck
ebenso, und viele grüße
  (#116) Old
Thumbs up First successful installation of Retail SL CD on the Dell Mini 10v - 09-02-2009, 01:40 PM
Originally Posted by meklort View Post
NetbookInstaller currently has a bug where it touches a file that snow leopard doesn't like being modified / does it incorrectly
If you install Snow Leopard without having netbook installer patch the install, you can then boot using the usb drive and wireless will work.
Yesterday night I've tried using Chameleon to boot and install directly from the original Snow Leopard Retail CD and it works for my Dell Mini 10v INSPIRON 1011, installation and setup completes successfully and I tested some browsing using Safari over wi-fi connection. Webcam works too.
I guess now I need to patch at least the sound because not using NetbookBootMaker it is not working now.
I will let you know about any other problems/issues.
  (#117) Old
Default 09-02-2009, 05:45 PM
if i try to boot in single modus with -s i get a kernel panic with this message:
Mac OS Version:
Not Yet set
what should i do?
greetings
  (#118) Old
Default 09-02-2009, 06:19 PM
okay, i tried a second time and now its possible to start with -s. how can i finish the setup with command line? there is no gui.
thanks a lot
  (#119) Old
Default 09-07-2009, 02:56 PM
Here is a link to solutions to that problem InfiniteMac Wiki: Known Issues
  (#120) Old
Default 09-07-2009, 03:00 PM
Actually, this is discussed in the stickied thread at the top of this forum.
This is an old thread.
Functioning Hibernation
« Non Dell "Hackintoshting" Question | Hybrid Mac/Windows CD: How Do You Access the Windows Part? »
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/700-will-osx-10-6-snow-leopard-run-mini.html
Posted By For Type Date
Dell Mini 9 users : Please advise on Snow Leopard installation and operation This thread Refback 08-27-2009 12:35 PM
Guide: Snow Leopard on PC 10a432(GOLD MASTER!!!) | TeknoJunkie This thread Refback 08-14-2009 06:08 PM
