mikey19 mikey19 is offline
Post HELP! How do I reset "Display" mirror setting - 04-23-2009, 07:00 AM
Hi guys,
need some help. I was checking out how my mini works with an external display. The extended desktop works well, which is what I need, but I accidentally check the "mirror display" box. Now both screens are scrambled and I cannot even see where that box is to uncheck it. :x
Does anyone know how to edit some configuration file so I can "uncheck" the box and have my computer back to normal with the extended display?
Also just a question: Can I use the mini9 with the display closed, connected to an external keyboard, mouse, and display?
Thanks for the help
mira mira is offline
Default Re: HELP! How do I reset "Display" mirror setting - 04-23-2009, 07:10 AM
have a look here:
and here
Clamshell mode is some kind of a hussle: won't do even on my MacBook Pro. Whereas Windoze does it fine...
Dell Mini 9 | Mac OS X 10.5.6 | 2 GB RAM | 16 GB STEC SSD | Bios A04
DellEFI 1.1 | USB Legacy Mode off | Bluetooth on | 1,3 MP camera | Wake from USB off | Apple Wireless Keyboard (Plastic, Bluetooth)
« osx installation with a mac | does MAC OS X 10.4 work on the mini 9? »
