SkyWriter SkyWriter is offline
SkyWriter's Avatar
Default Startup problem with Inkscape - 04-17-2009, 03:01 PM
i installed the most recent version of Inkscape; the open source replacement for Illustrator. the problem is when you startup Inkscape nothing happens; no window pops up but the application icon is in the dock. I couldn't get to the application until i started up GIMP. after clicking on GIMP the Inkscape application window finally popped up, then a couple of seconds later GIMP did as well. i tried to upgrade X11, that didn't help. I can't get inkscape to work unless i use GIMP too.
anyone else have this problem with Inkscape? oops url
Problems with external displays or projectors in OS X? Try MirrorDisplays2!
Got Static?
« trackpad not working after sleep | INPUT OUTPUT ERROR during Restore or Creating Image »
