KateKat KateKat is offline
Default DellEFI 1.1 Battery Weirdness - 04-03-2009, 07:09 PM
I've successfully installed DellEFI and everything including sleep works just fine, however the battery behavior is a little weird when it runs low. I get the usual battery warning at around 10 mins left however when we get to the last few minutes (sometimes gets to zero) the battery display goes to "(calculating)", if I go into the System Profiler then we get:
Model Information:
Serial Number: Dynapack-W953G-Lion-Unknown
Manufacturer: Dynapack
Device name: W953G
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0000
Hardware Revision: 0000
Cell Revision: 0000
Charge Information:
Charge remaining (mAh): 0
Fully charged: No
Charging: No
Full charge capacity (mAh): 1952
Health Information:
Cycle count: 100
Condition: Check battery
Battery Installed: Yes
Amperage (mA): -720
Voltage (mV): 12983
Although the battery charge shows zero, today I tested the machine to powerdown, WiFi on, web browsing, I got another 15 minutes of operation before the battery gave out and the machine powered off. Is this an internal battery calibration issue or a DellEFI issue???
solar solar is offline
Default Re: DellEFI 1.1 Battery Weirdness - 04-03-2009, 07:29 PM
I am having exactly the same issue. Battery seems to be pretty accurate but when i get the low battery warning at about 10 min power left it goes to a never ending calculating.
Not a very big issue but i also would like to know what is causing this. A battery problem or a dellefi problem?
Running dellefi 1.1 final.
meklort meklort is offline
meklort's Avatar
Default Re: DellEFI 1.1 Battery Weirdness - 04-03-2009, 07:42 PM
I think its a battery problem. Since the battery is reporting no charge (its says its empty), the kext is unable to calculate a time remaining.
That or the dsdt / kext might be wrong.
A third possibility is that after the battery reports its empty, it may be reporting an estimated time remaining till it really is empty.
My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a invite? message me.
FrankB FrankB is offline
Default Re: DellEFI 1.1 Battery Weirdness - 04-03-2009, 07:45 PM
I would guess that once the battery reports 0 mAh, there's no time to calculate. The driver should probably just report 0 minutes left but that's a corner case.
Dell Mini 9 | Mac OS X 10.5.7 | 1 GB RAM | 16 GB STEC SSD | 1.3 Webcam | Bluetooth
BIOS A04 | USB Legacy Mode: OFF | Bluetooth: On | Dell EFI 1.1 | Dropbox
« please help please post | Itunes store signin from Mini 9? »
