levil levil is offline
Default Reinstalling DellEFI from 'not' within OSX? - 03-31-2009, 10:36 PM
So DellEFI1.1 killed my system. It got the multi-language grey press on/off button for long error at boot up. Can't figure it out, but it is what it is. It might have something to do with the fact that I am installing on an external USB that is not a 100% stable, occasionally hangs at boot. But 1.07 worked fine at second boot the latest, and usually at first.
Next I did a system restore from Time Machine using the Install Disk. Now that doesn't boot either. I am told it is because I need to reinstall the EFI (as TM does not back those files up.) Unfortunately I cannot boot the system even with the Type132.
Did a raw reinstall, update to 10.5.6, install DellEFI1.1. That gives me the same multilingual error.
Now I am doing the system restore again using the TM but I suspect it won't out of the box. But I suspect it won't work as is. Is there any way I could install DellEFI from not within OSX (like using the Install DVD.) Alternatively could I just use another OSX computer to install DellEFI on the drive I run OSX from? So far I found nothing on how but I'd appreciate the help. (On any of these issues.)
Thanks, Cheers. L
meklort meklort is offline
meklort's Avatar
Default Re: Reinstalling DellEFI from 'not' within OSX? - 03-31-2009, 11:09 PM
You can install the bootloader manually and the kexts if you patch them. I may look into making it so dellefi can install to a specific hdd / partition in the next version.
My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a invite? message me.
Default Re: Reinstalling DellEFI from 'not' within OSX? - 04-01-2009, 05:31 AM
The latter would be great. Could someone help me with the former, maybe point me to a place where I can find info on this? Thanks. L
« Battery Problems... | Alarm Clock 2 and the mini »
