Default Ethernet Not Working... Need Help - 10-31-2008, 01:32 AM
Guys
I noticed yesterday the Ethernet is not working. I don't see this on the NOT WORKING list, so I guess it should be something I haven't read about or some update (kext) I missed.
Can anyone shed some light in here?
Thanks
Default Re: Ethernet Not Working... Need Help - 10-31-2008, 02:12 AM
I don't think anyone ever tried it before.. heh..
Default Re: Ethernet Not Working... Need Help - 10-31-2008, 02:22 AM
Works fine.. I turned off airport, plugged in the cat5 cable, went to the network pane in System Pref's, and it said new network found, click apply. So I did, and it works fine. I'm posting from a wired ethernet connection on my 9 right now. And on a side note, it stays working after sleeping.
Are you using the Wind distro? Did I mention that distro doesn't work very well on our computers?
Default Re: Ethernet Not Working... Need Help - 10-31-2008, 02:36 AM
I'm actually seeing a pattern here...
I'm on the MSIWind Distro... so I guess that IS the issue hehe :mrgreen: , I'll be moving to one of the Forum methods tomorrow, period.
Thanks Guys.
Default Re: Ethernet Not Working... Need Help - 10-31-2008, 04:43 AM
Yeah on the so EFI boot method (So nicknamed my method) ethernet works like a charm
Default Re: Ethernet Not Working... Need Help - 11-02-2008, 02:09 PM
i found that if u reboot with ethernet plugged in, it works.
thats on the wind install
regards
Default Re: Ethernet Not Working... Need Help - 11-02-2008, 11:05 PM
I moved to the Type11 Method. Everything works perfectly.
The ethernet works great, currently im connected using it, so its A OK!
I recommend you all Mini 9 owners to apply that one.
Default Re: Ethernet Not Working... Need Help - 11-18-2008, 01:58 PM
i was just going through everything and never thought to try the ethernet but i to cant get it to work... im using the iDeneb method... any ideas? thanks guys
Default Re: Ethernet Not Working... Need Help - 11-18-2008, 04:05 PM
Here is the driver you need.
Default Re: Ethernet Not Working... Need Help - 11-18-2008, 04:15 PM
install looks to have gone ok but still no ethernet
« What methosd to install Mac OS in 8GB Dell Mini? | How hot does it run? »
