bmcclure937's Avatar
Default Re: Running OSX from a USB Stick/SD Card - 03-29-2009, 11:11 PM
It is an extremely bad idea to run an operating system from a USB flash drive or SD card :shock:
The multiple reads and writes on the flash memory will not only be slow, it will degrade the memory quickly... and the average lifetime of flash memory is 50,000 reads/writes (some as low a 10,000, some as high as 100,000)
Meklort's Blog | NBI Google Code Page | -- the best OSX installation guides
chazzek chazzek is offline
chazzek's Avatar
Send a message via AIM to chazzek
Default Re: Running OSX from a USB Stick/SD Card - 03-29-2009, 11:33 PM
The same applies to running an OS from the internal SSD -- it's made of flash memory too. Generally, though, you can expect several years of operation from flash memory, even with heavy write usage.
Dell Mini 9 | Mac OS X 10.6.2 | 2 Jigabytes RAM | 32 Jigabyte STEC SSD | Bios A05
NetbookInstaller 0.8.3 | USB Legacy Mode off | No camera
gordon.jackson gordon.jackson is offline
Lightbulb Re: Running OSX from a USB Stick/SD Card - 04-06-2009, 02:11 PM
Have to say, now works fantastically,
I'm running great speeds off the USB Hard Drive, boots straight in if it's present and to XP if it's not there which is exactly what I wanted.
Because of the capacity, I have the Full Ilife 09 suite which is what I wanted
Great forum and the Dell utils are amazing, everything works
Thanks for all the input to make this possible
  (#14) Old
msherwin msherwin is offline
Default 06-23-2009, 02:45 AM
Originally Posted by LGSilva View Post
Just to share my experience...
Yesterday I got my mini with 1gb ram / 4gb hd. My runcore still weeks away but I wanted my hackintosh now hehehe.
I went to compusa and got a ocz rally2 16gb usb drive to use as my main storage.
It went something like this:
- on my windows machine I formated the rally2 using transmac and the retail osx image.
- I used a 2gb for my dellefi boot drive
- a 16gb sdhc card for temporary install
I booted from the 2gb, the installation started from the usb 16gb to the sdhc 16gb.
After a while it was done, then back on my windows machine I cloned from the sdhc card to the usb drive as the mini can't boot from the card reader.
I finished the installation and now I'm typing this from my hackintosh running from a 16gb usb drive and it's very useable.
My problem is with the sleep part as I need to have the legacy usb on to boot from the usb.
Could I get more specifics on putting OSX on an USB flash drive? I am a novice in this area. Thanks.
  (#15) Old
20psirabbit 20psirabbit is offline
Default 06-24-2009, 02:21 AM
+1, unfortunately i only have PCs in my house, so i'd like to save the step of having to use a mac as well for my install.
« Paralells on a Hackintosh | Quicktime Upgrade Botched »
