bmhome1 bmhome1 is offline
Default Re: Does it have to be a Runcore SSD? - 03-20-2009, 09:51 PM
Originally Posted by Dravor
There really are no other options, you can purchase directly from Hong Kong via Ebay.... but just remember, there is a lot of identical looking product sold in China. But clones don't always work nearly as well as the real thing. And this is a drive you are going to put your data on.
There is exactly ONE eBay seller of RunCores from Honk Kong: timfvn sells original sealed packaged RunCores complete with identical Model number and serials. Planting speculation about fakes is purely FUD and unnecessary attack against an honest supplier.
Black Mini 9 (free with DSL package) | 2GB Patriot RAM | 32GB RunCore | 16GB Transcend 6 SDHC | TWO internal 16GB microSDHC on USB controller | EETI Touchscreen | Windows XP
MSATech MSATech is offline
Default Re: Does it have to be a Runcore SSD? - 03-21-2009, 06:09 AM
I just bought my 16GB RunCore from (Ireland) and did not have any issues other than it sitting in Customs for abut a week.
My Mini....
Dell Mini 9 (White), 2 GB RAM upgrade and RunCore 16 GB SSD for OSX
STiMULi STiMULi is offline
Default Re: Does it have to be a Runcore SSD? - 03-21-2009, 05:54 PM
I got my Runcore from MDD.
I couldn't be happier with MDD or the SSD.
A 64GB makes my 9 rock!!!
Mini 9 MacBook Aspen White
Runcore 64GB | 2GB RAM | ATP 16GB C6 SDHC | 1.3 Webcam | Bluetooth | OSX 10.5.6 | Fusion w/Windows XP | CrossOver | DellEFI 1.2A5 | BIOS A04 | 77Whr Battery
Will install OSX for Food
« Safari 4 beta consistently crashes? | Bluetooth turned off »
