ToXiC625 ToXiC625 is offline
Default 10.5.6 Boot Up Problem - 03-11-2009, 08:56 PM
I was wondering if anyone else has this problem and knows a solution or knows whats wrong with my dell mini 9. Sometimes when i turn on my dell mini 9 it freezes at the Apple Logo screen with no spinning ring. If i restart the mini it boots usually. Sometimes it takes 2 reboots to boot up. I installed the Combo Update and the Dell efi already.
bob72 bob72 is offline
Default Re: 10.5.6 Boot Up Problem - 03-11-2009, 09:09 PM
I get the same sometimes, no idea why. Tends to stick on a blue screen for me.
It rarely happens but when it does it takes quite a few boots to solve. Last time it lost my wallpaper setting too oddly?
srvmdm srvmdm is offline
Default Re: 10.5.6 Boot Up Problem - 03-11-2009, 09:18 PM
You're not alone. I think I get the Apple screen without the spinning logo after I let the machine fall asleep (cover open). I hold down the power button, and then sometimes I get that problem trying to restart. A second time seems to always work. I'm guessing it has something to to with improper shutdown in my case, but don't know about yours.
jhillestad jhillestad is offline
Default Re: 10.5.6 Boot Up Problem - 03-11-2009, 09:50 PM
just out of curiosity what SSD drive are you using ? maybe it can be pin pointed to that ... it sounds like the drive is not given a ready state to the bios and its waiting.... you might want to reinstall the dellefi again too....
I have been using a runcore 32gb and its been flawless , even in sleep mode.
« Question on Running Permissions | OS X Installation using regular USB hard drive? »
