Default Everything works except sound and boot - 03-08-2009, 05:42 PM
When I got the OSX installed (10.5.6) I opened up the DELLEFI in DellMini9Utils I chose easy installation. Everything installed correctly except the Dell mini 9 extensions. It says
Could not install Extensions. Error 1
I am guessing that has something to do with my boot. Whenever I boot I have to put in the dellefi image and press esc. Then I have to choose the hard drive and press enter or else it will just be stuck at the apple boot screen. Also my sound does not work. I have bios version a01, but I don't know how to flash it. If anyone could help me that would be great. I would love to have my mini 9 working 100 percent without using a flash drive to boot it up.
Default Re: Everything works except sound and boot - 03-08-2009, 06:24 PM
I suggest you run DellEFI again and select to do "Custom Install" then make sure to re-install the Extensions. This will probably fix it.
Dell Mini 9
8GB SSD, 1GB RAM
OS X 10.5.6
Default Re: Everything works except sound and boot - 03-08-2009, 06:31 PM
That is what I did, I redownloaded the dellefi and went into the utils and it did the same thing.
« Silverlight for OSX installed? | HOWTO: Boot XP from USB! »
