| Junior Member Posts: 7 Join Date: Feb 2009 Location: Austin, TX | I was successful with a Samsung external (non-slim) DVD writer - I'm pretty sure this is the one: http://www.samsung.com/us/consumer/deta ... S184M/AMBN I dont know if it is the best drive for the job as it seemed really slow, and at the initial boot of the Leopard retail DVD I didn't get any response for 1-2 minutes, causing me to think the drive was not compatible and the install wouldnt work... and then it started installing. Maybe that's normal for all drives. |
| Guest Posts: n/a | This is the one I have: (LG GP08LU10) http://us.lge.com/products/model/detail ... LU10.jhtml I did have to unplug it and plug it back in at the '9f' prompt like in the How-To's |
(#4)
(#5)
| Junior Member Posts: 10 Join Date: Mar 2009 Location: Birmingham, AL | I have this one on order. I will report my findings on Tuesday, after it arrives: http://www.newegg.com/Product/Product.a ... 6827151178 Mini 9, also Obsidian Black with 2GB and a 32GB SSD running 10.5.8. |
(#6)
| Member Posts: 66 Join Date: Dec 2008 | Quote:
http://tnkgrl.wordpress.com/2008/06/...drive-for-all/ HardMac found a smaller board that's easier to fit, no crystal moving here: http://forum.hardmac.com/?showtopic=5553&pid=10759 HardMac's solution uses this USB/IDE board from IDOTPC: http://www.idotpc.com/thestore/pc/vi...?idproduct=484 I did this mod myself, it is real simple: unsolder four wires from old board, solder wires to new board, done. It is recommended to plug this, as well as any other USB bus-powered drive, into the USB port closest to the power connector. There's also some information on this forum: http://mydellmini.com/forum/macbook-...ive-t1754.html http://mydellmini.com/forum/macbook-...=t&sd=a#p21437 [s 7y92wb3]Insert search nazi comment here.[/s 7y92wb3] ![]() | |
(#7)
| Guest Posts: n/a | Quote:
So: 1. Almost ALL DVD drives should read the OS X dvd 2. Make sure you have a newer USB interface. Like: http://www.vantecusa.com/front/product/view_detail/266 P.S. The same goes for external Hard Drives. My first OS X install is on to an external HD (I only have 8GB STEC SSD) If I used my older drive cages, I would get a read/write error in OS X Disk Utility when trying to partition a GUID HFS+ setup. I didn't have that problem with the Vantec interface. | |
(#8)
| Junior Member Posts: 7 Join Date: Mar 2009 | I used this Rosewill, installed OS X on Dell Mini 9 and a MSI Wind: http://www.newegg.com/Product/Product.a ... 6827190020 |
(#9)
| Member Posts: 67 Join Date: Feb 2009 Location: Denver | FYI, microcenter.com is selling an external Dual Layer Slim Burner for $65 at the moment... it's in their online weekly magazine if you're interested. It's looking pretty appealing to me ![]() Dell Mini 9 - 64GB SSD - 2GB RAM http://www.cocoatouchapps.com/ |
(#10)
| Junior Member Posts: 11 Join Date: Mar 2009 | Quote:
