somms somms is offline
somms's Avatar
Default Re: Possible to swap fn/ctrl? - 03-08-2009, 10:09 PM ... #wp1037348
Setting the Keyboard Matrix
Turn off your computer (see Turning Off Your Computer).
If your computer is connected to the AC adapter, disconnect the AC adapter from the computer.
Press and hold the following key combination for the desired keyboard matrix:-
United States: <Fn><S>
United Kingdom: <Fn><K>
Japan: <Fn><J>
Korea: <Fn><E>
Connect the AC adapter to the computer and then plug it into a wall outlet or surge protector.
Release the key combination.
<Fn>keycombos look like they provide limited BIOS-level adjustments based on keyboard regions...not exactly sure the matrix differences are but possibly this maybe something to consider...
« SDXC | Snow Leopard Beta Anyone??? »
