(#11)
| Junior Member Posts: 5 Join Date: May 2009 | It works!!! Just take into consideration that you do need Ubuntu 8.10, if you download 9.04 (like i did the first time) you will need a new version of Aircraft, more info here: Ubuntu on the Dell Mini 9: Aircraft Manager for Ubuntu 9.04 |
(#12)
(#13)
| Member Posts: 41 Join Date: Mar 2009 Location: New Mexico, USA | What are the symptoms you are seeing? Do you have a prefs pane? can you see the bluetooth icon in the menu bar? Dell Mini 9 Aspen White | BIOS A05 | Mac OSX 10.5.7 | DellEFI 1.2a5 | Meklort's Touchpad Driver | Direct Runcore Install Method | 64 GB Runcore SSD | 2 GB RAM | 16 GB SD | Bluetooth: [enabled] | Bluetooth Terminal Mod | USB Legacy Mode: [disabled] | 1.3 MP Webcam | Life is Good |
(#14)
(#15)
(#16)
(#17)
(#18)
(#19)
(#20)
| Member Posts: 41 Join Date: Nov 2009 | Any easier way to enable BT after installing a BT module on my 10V in OSX? This and wireless are my last hurdles. I don't have an XP HD nor do I want to deal with linux installs... ---------- Post added at 07:49 PM ---------- Previous post was at 07:19 PM ---------- Forget that last post. I got it running. Mini 10 Bone Stock XP no mods for Beersmith/mkv2vob/some light porn use |
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/4384-how-enable-bluetooth-osx-without-xp.html | ||||
| Untitled document | This thread | Refback | 09-01-2009 05:32 PM | |
| Find DELL J613H 2.1 Bluetooth module + cable 4 mini9 mini 9 on eBay Global Buying, with worldwide deals on items in all your top categories | This thread | Refback | 08-30-2009 01:20 AM | |
| rushy2uk's Bookmarks on Delicious | This thread | Refback | 08-14-2009 05:49 PM | |
