| Member Posts: 43 Join Date: Jan 2009 | I just converted from the Type11 method to the DellEFI version (which went relatively smoothly, you should consider it - you can do it straight from the Mini 9 without hooking anything else up to it). I did not/not install the mirror option. This evening I plugged my Mini 9 into my TV. That's effectively the same as plugging it into a projector - just another VGA screen. Anyhow, it showed up as another monitor hooked into the Mini 9 to the right of my existing screen (ie- drag off the right and your mouse appears on the second monitor). I moved iTunes over onto the TV and was able to nicely display Star Wars. Looked pretty good - just like from my AppleTV. I didn't watch the whole thing, but about 15 minutes with some action looked good. If you were doing a Powerpoint presentation or something from the web, it would work the same way. Just put the display window onto the projector and you will be good to go. DellEFI also let's you do mirroring using an older video driver. Not sure of the necessity for that in your purposes, but that option is also available. The new Safari 4 beta is supposed to be pretty fast. I haven't tried it though. Firefox wouldn't be too bad either. You can run apps or data from the SDHC/USB flash drive. If you don't have to, I wouldn't for a presentation, but that is personal choice. I should try the Ethernet port on my Mini 9, but haven't yet. So I don't know about the orange light - check under Network in System Preferences and turn off Ethernet, otherwise I have nothing. Sorry. You are motivating me to experiment later though! Hope this helps. Good luck! iMac G5, 8GB Original iPhone, 30GB 5G iPod, 4GB iPod Nano, 250GB Apple TV Dell Mini 9, 2GB RAM, 32GB SSD, Leopard OS X Free 2GB DropBox via this link: Click Here ---> https://www.getdropbox.com/referrals/NTE0NzU0NDM5 |
(#4)
| Member Posts: 34 Join Date: Feb 2009 | Thanks for the help with the projector paduck. I fixed the orange light from the Ethernet port, all I had to do was turn off the Ethernet in the network utility. And what are the advantages of the Dell EFI version and the Type 11 version? http://mydellmini.com/forum/howto-in...7-9-t1106.html <I used that method just to clarify. |
(#5)
(#6)
| Junior Member Posts: 23 Join Date: Apr 2009 | Quote:
4 GB SSD with Ubuntu 9.04 Netbook Remix | 32 GB Runcore SSD with Mac OS 10.5.7 | |
(#7)
| Senior Member Posts: 354 Join Date: Mar 2009 | after trying different terminal/mirroring command, etc... method that uses the [alt][space] calling the application found below finally worked for me. http://www.fabiancanas.com/Fabian_Ca..._Displays.html i had to call the program several times, but finally it stuck and mirroring/external worked on a recalcitrant Dell projector. also still works with my other monitors. no idea why it takes several incantations the first time, but it seems to work fine after that. Problems with external displays or projectors in OS X? Try MirrorDisplays2! http://www.mydellmini.com/forum/mac-...html#post73180 Got Static? http://www.mydellmini.com/forum/gene...io-static.html |
(#8)
| Senior Member Posts: 354 Join Date: Mar 2009 | ok, so using it for real at a presentation, i found that it doesn't work with 'spaces'. when you switch spaces the screen corruption returns for spaces that did not have the power point application. still better than toting an extra XP bag around. Problems with external displays or projectors in OS X? Try MirrorDisplays2! http://www.mydellmini.com/forum/mac-...html#post73180 Got Static? http://www.mydellmini.com/forum/gene...io-static.html |
(#9)
(#10)
| Senior Member Posts: 354 Join Date: Mar 2009 | Problems with external displays or projectors in OS X? Try MirrorDisplays2! http://www.mydellmini.com/forum/mac-...html#post73180 Got Static? http://www.mydellmini.com/forum/gene...io-static.html |
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/4232-osx-external-monitor-projector-qeustions.html | ||||
| Blogmarks.net : Public marks from user an_ta with tag mini | This thread | Refback | 08-08-2009 12:12 AM | |
| Blogmarks.net : Public marks from user an_ta | This thread | Refback | 07-11-2009 05:06 PM | |
| jfritsche's Bookmarks on Delicious | This thread | Refback | 06-16-2009 01:21 AM | |
