Default Leopard installed, but battery not working - 03-01-2009, 04:37 AM
hello all
i installed os x, but now my battery wont charge, any tips?
I installed with the EFI method, but when I remove the ac wall adapter the computer just turn off, is this common?
thanks
Default Re: Leopard installed, but battery not working - 03-01-2009, 04:54 PM
bump
Default Re: Leopard installed, but battery not working - 03-01-2009, 04:58 PM
Originally Posted by alhelo
hello all
thanks
This must be hardware related. Nothing to do with the OS. Most likelly a defective battery.
Try taking the battery out and put it back in...
Dell Mini 9
8GB SSD, 1GB RAM
OS X 10.5.6
Default Re: Leopard installed, but battery not working - 03-01-2009, 05:02 PM
You might want to give this a try:
With battery installed and Mini powered off, remove the power adapter.
While holding down Fn+B reconnect the power adapter, the front panel lights should flicker momentarily.
Release Fn+B then press the Mini's power button. The Mini should beep once then do nothing.
Disconnect the power adapter, disconnect and reconnect the battery then reconnect the power adapter.
Turn the Mini back on and after booting into the OS confirm that the battery is now charging.
If not on BIOS A03 or A04, it is also recommended to flash up to this latest BIOS: http://www.mydellmini.com/forum/bios-up ... t1063.html
Dell Mini 9
8GB SSD, 1GB RAM
OS X 10.5.6
Default Re: Leopard installed, but battery not working - 03-02-2009, 02:52 AM
thanks for the advice, I did that. When I did the Fn+B instead of making of making one beep it makes three [long short long] and repeats that. When I boot it up it says the battery is at 0% and that it is not charging the battery. Any advice?
Default Re: Leopard installed, but battery not working - 03-02-2009, 07:23 AM
I had this problem too. My mistake was, I checked the option under windows for not loading the battery until next reboot. Then I installed Leopard.
I solved it with a SSD from a pal, who had still his origininal windows installation. So I swapped the SSDs, rebootet once or twice and made sure the battery is loading. Then swapped the SSD back. The battery was then behaving normally under Lwopard.
I think it's similar to the bluetooth-issue: Some poeple reported bluetooth not functioning under osx if it was disabled under windows. There must be some Hardware-Bios-Extensions which are not supported by the OSX drivers (yet).
Just my 2 €-Cents
Default Re: Leopard installed, but battery not working - 03-02-2009, 08:32 AM
Just my 2 €-Cents
Would you mind telling me (us) where this option is in Windows.
Wouldn't want to make the same mistake you did when I get my mini, cheers.
Default Re: Leopard installed, but battery not working - 03-02-2009, 08:23 PM
I had ubuntu on it previously, was there a setting i need to change on it?
Default Re: Leopard installed, but battery not working - 03-03-2009, 04:07 PM
The problem was i set airplane mode under ubuntu, i had to replug the old ssd and disable airplane mode and it worked fine after.
Default Re: Leopard installed, but battery not working - 03-03-2009, 04:31 PM
The problem was i set airplane mode under ubuntu, i had to rep[*]lug the old ssd and disable airplane mode and it worked fine after.
« weird sleep issue | HELP -- osx install question method 3 step 4 »
