| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | Are you formatting with with the FAT (MS-DOS) file system or Mac? Not sure that should make a difference, but still. If it weren't for the fact that it looks like you're trying to do it all off one drive, I would have recommended just using a small flash drive or using the disk image I created. (The last one won't work for single USB installs, only dual USB.) Also, try typing in ".05" in the GB field, this should change it to MB. Sometimes you just need to nudge Disk Utility to get it to do smaller partitions. http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#4)
| Junior Member Posts: 13 Join Date: Feb 2009 | Thanks for the reply. The file was there. I was missing the /a. It's odd. I type in .05 [enter]. It displays 1 GB and it also says.. *Denotes that some partitions are less than displayed in the list. But it never switches to MB. If I try using my thumb drive, it changes to MB. I would use my thumb drive, but I got some important info on there. I don't like messing with it. And I would buy another one, but I'm stuck in Hell (Iraq). Can I get away with using a 1 gig partition for the EFI part? |
(#5)
| Member Posts: 83 Join Date: Jan 2009 | Quote:
Alec Dell Mini 9 (UK), 16Gb SDD, 2Gb RAM, Mac OS X 10.5.6 | |
