bamf bamf is offline
Default Re: Trying to Learn; Please Help - 02-21-2009, 03:43 PM
Some other things for the OP to note too (and I don't know how much Unix/Linux/etc. experience you have):
In *nix (of which OS X is since it is built on BSD), there are a few conventions for file paths that you should know. If you see someone say "/" that is the Windows equivalent of saying "C:\" (assuming you only have 1 drive in your Windows system). In *nix all paths begin with that "/" path.
In Windows we tend to think of things based on which drive they are one. You many have multiple hard drives, so you might have C, D, E, etc. + a letter representing your CDROM drive (and potentially other things too - SD drive etc.). In *nix you can get to everything by starting with the / path. So when you mount something in OS X, you can find it in /Volumes/NameOfWhatYouMounted.
If you need to make a call to a file in a relative path in *nix, you can use the convention "./" to signify run from the current location. So if you were in terminal and wanted to run a file that is not in your executable path, then you can call ./applicationName (assuming you are already in the correct directory and that the file is marked as "runnable".
Just a few things I thought might be helpful for someone switching over from the Windows world...
Dell Mini 9 with a STEC 64gb SSD running OS X Leopard 10.5.6
MBP (Early 2008 model) 2.4, 200GB 7200 RPM, 4GB
Mac Mini 1.83Ghz, 80GB, 4GB
The random musings of Bamf -
lugesm lugesm is offline
lugesm's Avatar
Default Re: Trying to Learn; Please Help - 02-21-2009, 03:52 PM
Thanks, bamf.
Very helpful. Mac is a whole different world as compared to Windows.
Dell Mini10v, 64GB RunCore Pro IV SATA SSD, 2GB Memory, A06 BIOS, 10.6.7, NBI 20100616212351, Bluetooth enabled (external dongle), USB Legacy disabled.
« 64GB Dell SSD formats to 57GB? | n00b »
