jhillestad jhillestad is offline
Default using sdhc w/usb adapter install ? - 02-12-2009, 12:20 AM
I have made an os x boot drive using an external normal usb drive.... I was just curious if I took a 16gb sdhc stick in a usb holder and plugged it into the usb port of the dell 9 would I be able to install os x on that and it function ? I know you cannot use it in the media stick part of the dell9 but once I use the usb adapter will the os x install be the same as it was for the usb external drive that I used ?
My internal ssd drive has win xp and I am waiting for a runcore ssd but was tired of this big usb external and was looking for a lighter type option....
yan_vn yan_vn is offline
Send a message via MSN to yan_vn
Default Re: using sdhc w/usb adapter install ? - 02-12-2009, 02:02 AM
I am not sure your SDHC reader will be seen as a USB Flash dongle.
In fact in modern PCs mostly all peripherals are connected using USB internally, so the way you want to go will not differ a lot from the standard internal reader of the Mini9...
Well, I think... never tried in fact.
Yannick DEVOS - Nature-Mekong
hypnotmica hypnotmica is offline
Default Re: using sdhc w/usb adapter install ? - 02-12-2009, 09:04 PM
From using the SEARCH FUNCTION HERE:, it appears you can use a USB reader with an SD card to boot.
Vostro A90 | 64GB SSD | 2GB RAM | BIOS: Dell Mini 9 A05 | Mac OS 10.6.1 | 1505 802.11N Wifi | .3MP WebCam
mechdrew mechdrew is offline
mechdrew's Avatar
Default Re: using sdhc w/usb adapter install ? - 02-13-2009, 01:29 AM
I've personally used a Sandisk Mobile SD+ with a 4 GB microSDHC card and Lexar SD card reader to help me with the install process. Both booted up just fine so I could use my 8 GB Sandisk Cruzer with the Leopard DVD on it. Your mileage may vary, but I've never had a problem with any of my SD or USB cards, just sometimes you have to do a little dirty work.
« ATTN: Quicksilver users | Dell Mini 9 + OSX + iPhone = Perfect Road Warrior Solution »
