Toonvox's Avatar
Send a message via Skype™ to Toonvox
Default Re: SD Card Compatibility Issues - 03-01-2009, 06:17 PM
Here's mine. It's a Kingston 32gb Class 4 SDHC card which always unmounts after erasing/partitioning and never mounts when you reinsert it. Thanks!
MAC Framework successfully initialized
using 10485 buffer headers and 4096 cluster IO buffer headers
IOAPIC: Version 0x20 Vectors 64:87
ACPI: System State [S0 S3 S4 S5] (S3)
Extension "com.apple.driver.AppleACPIPlatform" has immediate dependencies on both com.apple.kernel and com.apple.kpi components; use only one style.
mbinit: done
Security auditing service present
BSM auditing present
HDAEnabler: Copyright (c) 2008 by Kabyl
HDAEnabler: 05/05/2008 Added SPAudio support:Taruga
Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOService</string><key>BSD Name</key><string ID="2">disk0s2</string></dict>
PowerManagement is Starting
SDHCI: wakeup requested by thread: 0x037535d0
SDHCI: BaseClock = 50MHz
SDHCI: SD Clock = 390KHz
powerSD: 0x14832b2
SDHCI: initializing SD version 2.0 card
SDHCI: sending CMD55
SDHCI: sending ACMD41
SDHCI: got response to ACMD41: 0xc0ff8000
SDHCI: high capacity card
SDHCI: SD Clock = 25000KHz
SDHCI: RCA 0x00000001
Extension "com.apple.driver.AppleIntelIntegratedFramebuf fer" has immediate dependencies on both com.apple.kernel and com.apple.kpi components; use only one style.
AppleIntelPIIXPATA: Secondary PCI IDE channel is disabled
Extension "com.apple.driver.AppleIntelGMA950" has immediate dependencies on both com.apple.kernel and com.apple.kpi components; use only one style.
ApplePS2Trackpad: Synaptics TouchPad v7.0
Natit: Starting.
Chosen model GMA 950
Natit: Setting AAPL,HasPanel=<data not shown>
ATA Disk: Checksum Cookie not valid
BTCoexistence feature not supported!
wl0: Broadcom BCM4315 802.11 Wireless Controller
4.170.46.9Physical address is f0610000
TCR = 24800000
Extension "com.apple.driver.iTunesPhoneDriver" has no explicit kernel dependency; using version 6.0.
Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/PATA@1F,1/AppleIntelPIIXATARoot/PRID@0/AppleIntelPIIXPATA/ATADeviceNub@0/AppleATADiskDriver/IOATABlockStorageDevice/IOBlockStorageDriver/RunCore 32G-C SSD RunCore 32G-C SSD/IOGUIDPartitionScheme/Untitled@2
BSD root: disk0s2, major 14, minor 2
SDHCI: Response: 0x00400E00 0x5A7B5900 0x00F9FE7F 0x800A4040
SDHCI: Setting 4 bit mode
SDHCI: Response: 0x00400E00 0x5A7B5900 0x00F9FE7F 0x00000920
SDHCI: Successfully switched to 4 bit mode
Card Init: Host Control = 0x2
Card Init: Host Control = 0x3
Jettisoning kernel linker.
Resetting IOCatalogue.
AppleRTL8169Ethernet: Ethernet address 00:21:70:d2:7f:aa
AirPort_Brcm43xx: Ethernet address 00:23:08:29:e2:da
AppleIntelCPUPowerManagement: initialization complete
GFX0: family specific matching fails
display: family specific matching fails
Matching service count = 0
GFX0: match category IOFramebuffer exists
display: match category IOFramebuffer exists
InitRxRing
InitRxRing Fin
Mini9MuteControl: setting to 0
Mini9MuteControl: done
display: Not usable
AppleRTL8169Ethernet: phyWaitForAutoNegotiation TIMEOUT
MAC AUTH succeeded
AirPort: Link Up on en1
hfs_swap_BTNode: invalid node height (255)
node=0 fileID=8 volume= device=/dev/disk1s1
0 [Level 3] [ReadUID 0] [Facility com.apple.system.fs] [ErrType FS] [MountPt /Volumes/32gb SDHC]
HFS: Runtime corruption detected on , fsck will be forced on next mount.
Default Re: SD Card Compatibility Issues - 03-04-2009, 10:06 PM
ok, thanks
Default Re: SD Card Compatibility Issues - 03-05-2009, 12:34 AM
So are all Kingston SDHC cards biffing in the mini? I just purchased a Kingston 8GB SDHC Class-6 for my mini which will arrive tomorrow -- is it likely that this SDHC card won't work?
mini9 | 32gb runcore | 2gb | osx 10.6.2 | nbi 0.8.3 | a05
  (#14) Old
Unhappy Re: SD Card Compatibility Issues - 03-06-2009, 03:54 AM
I am not computer smart. I am a computer idiot. I want to add a 16BG SD card to my Mini 9. Can someone please explain to me if I can do this by just plugging it in? If not, can someone please explain to my like I'm a moron how to do this? I appreciate all of the work and advice that everyone fills these forums with!
  (#15) Old
Default Re: SD Card Compatibility Issues - 03-06-2009, 04:52 AM
Yes, just plug it in. It should work fine.
  (#16) Old
Default Re: SD Card Compatibility Issues - 03-07-2009, 12:07 PM
FYI optima 8gig SDHC from Best Buy (cheap $19) works just great.
Mini 10v, OSX 10.5.8, Bluetooth
  (#17) Old
Default Re: SD Card Compatibility Issues - 03-07-2009, 01:39 PM
Seems that a good test for a properly working SDHC card is to copy a large DMG file onto it (maybe even from a Windows PC), then try to mount the DMG.
This is what I cannot do. When I try to mount the DMG (more than one I tried), it fails with an input/output error.
Small files seem to be fine.
Give it a try with a full 4GB DMG file.
  (#18) Old
Default Re: SD Card Compatibility Issues - 03-08-2009, 02:47 PM
I can mount big DMG files through my Kingston SDHC 8GB Class-6 just fine. I've installed numerous applications this way. However, when I create new folders on my SDHC and then update iPhoto, iTunes to use these new Folders, everything seems great, but if I restart (or even if it goes to sleep) when I recheck the SDHC, the folders I created have disappeared. It seems that if I create the folders through my MacBook Pro, they remain, but not through my MacBook Mini. :/
BTW, I've formatted my SDHC to Mac OS Extended. I'm going to try going back to FAT32 to see if that helps. Then I will try my 4GB SanDisk Extreme III Card that I use for my Canon SD880IS. I'll let everyone know how that goes.
  (#19) Old
Send a message via MSN to zaned303
Default Re: SD Card Compatibility Issues - 03-08-2009, 05:34 PM
Hello
Using your method I was able to get my 8Gb SDHC card to work in the SD slot.
Thanks for your hard work!
Z
Thanks-
Z
Mini 9 | OSX 10.5.6 | 32GB SSD SuperTalent | WebCam | 2GB Crucial | 16GB PQI SDHC | Wifi N |
« Cisco VPN 'Error 51' issue | Silverlight for OSX installed? »
