scififan68 scififan68 is offline
Arrow Graphics corruption in System Preferences - 01-27-2009, 05:33 AM
I go through System Preferences and a bug like the photo attachment shows, any ideas on how to fix this annoying issue? Thanks
Edit: I wasn't sure if it's in the right place so if it isn't please move it.
Dell Mini 10v: Obsidian Black, 1GB DDR2 533MHz Ram, 1.6GHz Intel Atom, 120GB FUJITSU HDD, 6-Cell, Mac OS X Snow Leopard 10.6.3 Build 10D573 booted with Chameleon 2 RC5 pre6, Dell Wireless 1397 flashed! (Everything working, now featuring sleep when closing lid!)
Default Re: Graphics corruption in System Preferences - 01-27-2009, 07:35 AM
I don't see an issue in that screenshot, but there are some minor issues with our video driver. Usually just a small block of the screen won't be updated when renaming a file or something of that sort. Not a big deal, and we haven't found a better video driver option. It's standard GMA950 issues that any hackintosh running this video chipset will have.
bmaltais bmaltais is offline
Default Re: Graphics corruption in System Preferences - 01-27-2009, 12:45 PM
You are talking about the window title area? I never had this on my side... Did the MiniScript install worked without any errors?
Dell Mini 9
OS X 10.5.6
Dennis Dennis is offline
Default Re: Graphics corruption in System Preferences - 01-27-2009, 07:35 PM
I get the same corruption there, but if you click around, the buttons still work even though they're not visible.
Worst of all is in Photoshop (yes, CS4 works and is just about usable) where the corruption is a real pain. It's the only thing I would consider to be not fully functional on the Mini.
I also occasionally get a small square block appear just below the Apple logo in the top left.
« Google Code Project for MiniScript and Type11 ISO | Xcode »
