tikblang's Avatar
Default Problem on 2100 Latitude - "BUT" still hoping to run SL10.6.6 - 04-15-2012, 09:52 PM
Hi ,
I don't know if this is an obsession or I'm just tired with Windows running on Atom PROC, I'm not giving up and still trying to load Snow Leo on my Dell 2100. (Or should I start saving money and just get a real Mac?)
Anyhow, I was able to load 10.6.6 and I am having problem with the ff,
1. Wi-Fi (broadcom 4315 aka 4310) ( I have a 10v with the same wifi chipset and no problem with Wireless . It is also running 10.6.6.
2. HDA 272 Sound. No sound at all. Any help here since I have no clue on this.
3. My "AppleIntelIntegratedFramebuffer" appears to be incomplete.
So Any help and guide and the right direction will be much appreciated. Here is my dmesg below.
Thanks!
Tik
joerics-MacBook:~ eric$ sudo dmesg
Password:
npvhash=4095
PAE enabled
rtclock_init: Taking bus ratio path 4 (Intel / Apple)
TSC: Verification of clock speed PASSED.
TSC: Frequency = 1596.30396MHz, FSB frequency = 133.2533MHz, bus ratio = 12
Darwin Kernel Version 10.6.0: Sun Jan 9 16:31:48 EST 2011; legacy
kernel v6 :xnu-1504.9.26/BUILD/obj/RELEASE_I386
vm_page_bootstrap: 505639 free pages and 18649 wired pages
standard timeslicing quantum is 10000 us
mig_table_max_displ = 73
warning: skipping personalities in blacklisted kext
com.apple.driver.AppleIntelCPUPowerManagement
com.apple.driver.AppleIntelMeromProfile
com.apple.driver.AppleIntelNehalemProfile
com.apple.driver.AppleIntelPenrynProfile
com.apple.driver.AppleIntelYonahProfile
[SleepEnabler] Registering PowerManagement dispatch table with
PM_DISPATCH_VERSION 21...
[SleepEnabler] To disable (if the kernel panics), please specify the
boot argument pmVersion=0
Warning: Version mis-match between Kernel and CPU PM (0x 15 != 0x 15)
[SleepEnabler] Calling pmInitComplete()...
NullCPUPowerManagement::init: properties=0x52471c0
NullCPUPowerManagement::start
AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
calling mpo_policy_init for Quarantine
Security policy loaded: Quarantine policy (Quarantine)
calling mpo_policy_init for Sandbox
Security policy loaded: Seatbelt sandbox policy (Sandbox)
calling mpo_policy_init for TMSafetyNet
Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Copyright (c) 1982, 1986, 1989, 1991, 1993
The Regents of the University of California. All rights reserved.
MAC Framework successfully initialized
using 10485 buffer headers and 4096 cluster IO buffer headers
IOAPIC: Version 0x20 Vectors 64:87
ACPI: System State [S0 S3 S4 S5] (S3)
Can't get kextd port.
OSXRestart Version 1.5c \M-B\M-) Master Chief 2009
RTC: Only single RAM bank (128 bytes)
Kext com.apple.iokit.IOSMBusFamily - page 0x2f7d7000 is not backed by
physical memory.
Kext com.apple.iokit.IOSMBusFamily start failed (result 0xdc008007).
Kext com.apple.iokit.IOSMBusFamily failed to load (0xdc008017).
Dependency com.apple.iokit.IOSMBusFamily of kext
com.apple.driver.AppleACPIEC failed to load.
Kext com.apple.driver.AppleACPIEC failed to load (0xdc008015).
Failed to load kext com.apple.driver.AppleACPIEC (error 0xdc008015).
Couldn't alloc class "AppleACPIEC"
netkas presents fakesmc, a kext which emulates smc device
Previous Shutdown Cause: 0
DSMOS has arrived
mbinit: done (64 MB memory set for mbuf pool)
Warning - kext com.apple.driver.AppleIntelIntegratedFramebuffer has
immediate dependencies on both com.apple.kernel* and com.apple.kpi.*
components; use only one style.
use only one style.
From path: "uuid",
Waiting for boot volume with UUID 70DB2B80-5750-3711-A834-92E8BF428331
Waiting on <dict ID="0"><key>IOProviderClass</key><string
ID="1">IOResources</string><key>IOResourceMatch</key><string
ID="2">boot-uuid-media</string></dict>
wl0: Broadcom BCM4315 802.11 Wireless Controller
5.10.91.27
com.apple.AppleFSCompressionTypeZlib kmod start
Unable to detect alps
ApplePS2Touchpad: Synaptics capabilities query result 0xd0, 0x47, 0x31.
com.apple.AppleFSCompressionTypeZlib load succeeded
ApplePS2Trackpad: Synaptics TouchPad v7.2
USBMSC Identifier (non-unique): 20071114173400000 0xbda 0x158 0x5887
ApplePS2Trackpad: Detected toucpad controller "Standard TouchPad
(TM41xx134)" (ModelID: 0x1A0B1)
ApplePS2Trackpad: Initializing resolution to 2159 dpi
ApplePS2Trackpad: Compensating for geometry, setting resolution to 1338 dpi
ApplePS2Trackpad: Capabilities 53297, 0xD031
ApplePS2Trackpad: W Mode Supported
ApplePS2Trackpad: Palm detection Supported
ApplePS2Trackpad: Multiple finger detection NOT Supported
ApplePS2Trackpad: Trackpad supports extended W mode
ApplePS2Trackpad: Using peak detection method
Got boot device =
IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/IDE0@1F,2/AppleAHCI/PRI@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/M4-CT064M4SSD2
Media/IOGUIDPartitionScheme/MACOSXSL@2
BSD root: disk0s2, major 14, minor 2
warning: kernel was not built with custom dyld blob
AppleBCM5701Ethernet: 0 0 start - failed to find
Ethernet Low Power ACPI methods
AirPort_Brcm43xx: Ethernet address 00:26:5e:30:e7:1a
IO80211Controller::dataLinkLayerAttachComplete(): adding
AppleEFINVRAM notification
systemShutdown false
BCM5701Enet: Ethernet address b8:ac:6f:53:78:e8
Ethernet [AppleBCM5701Ethernet]: Link up on en0, 100-Megabit,
Full-duplex, Symmetric flow-control, Debug
[796d,0300,0de1,0300,45e1,0000]
ACPI_SMC_PlatformPlugin::start -
waitForService(resourceMatching(AppleIntelCPUPower Management) timed
out
ACPI_SMC_PlatformPlugin::registerLPCDriver - WARNING - LPC device
initialization failed: C-state power management not initialized
physical memory.
Kext load request buffer from user space still retained by a kext;
probable memory leak.
VID2: Not usable
joerics-MacBook:~ eric$ uname -a
Darwin joerics-MacBook.local 10.6.0 Darwin Kernel Version 10.6.0: Sun
Jan 9 16:31:48 EST 2011; legacy kernel v6
:xnu-1504.9.26/BUILD/obj/RELEASE_I386 i386
XPS-1340 Merlot | C2D-p8700 3 Gig | 1510N-wifi | 9500g SLI | 3 Gig RAM | Crap -HL-DT-DVD gs20n | => donate=given away.
Lat2100 | Yellow | 320-40G-g3 ssd | 1366x768 | 1397b/g | 2 Gig | 6-Cell | Got back from Ell
Mini9 - 1 Gig 16 gig SSD OSX10.6.3 to 10.6.7-unstable so_now_10.6.8 Very nice.
hack+, re-use+, recycl+, donate+
« Thank you all (from newbie) | Mini 9 RunCore 10.6.8 boots to kernal panic »
