hugheba hugheba is offline
Default Bluetooth PAN ... cable unplugged? - 01-21-2009, 07:18 PM
I am unable to create Bluetooth PAN network to Windows Mobile phone.
I've successfully paired my AT&T Tilt with my Mac OS X 10.5.6 Mini 9 Type11 install.
I start the InternetSharing app on my Tilt with the Bluetooth PAN as the connection type. On my Mini I choose my AT&T Tilt from the Bluetooth menu bar icon and select Connect to Network in the contextual menu.
Both my phone and bluetooth contextual menu say I am connected.
I try to browse a web page in safari or ping an address in terminal and am unsuccessful.
ifconfig shows no IP address for that interface and when I go the the Network control panel in preferences the Bluetooth PAN network interface says something about "cable unplugged".
When I try the same thing on my Macbook Pro it works fine.
Any suggestions or has anybody successfully set this up?
ccwillia ccwillia is offline
Default Bluetooth PAN not working - 10-19-2009, 01:12 PM
I have the same problem on my touch pro. I am able to pair the devices, but they dont appear to stay connected and there is no option to connect to my phone's BT PAN network. When I go to network preferences I can an option for BT PAN in the list but its not connected.
« Need help with snow leopard | Guest account bug in Snow Leopard; can loose all User account data »
