Default HELP: CPU not supported error? Dell 1012 - 09-19-2011, 09:01 PM
I am currently trying to hackintosh my 1012,
when i select the image with the arch=i386 -v
i get the following screen:
Any idea on what i can do?
Your help will be much appreciated, thank you
Matt.
Default 09-20-2011, 01:46 PM
Just an idea, not a real prognosis...the error says something about CPUPowerManagement, is there some kind of power management option in the bios you can shut off?
Default 09-20-2011, 09:31 PM
Nevermind sorted, I used a different version of nbi. Thanks tho
Default 09-20-2011, 09:49 PM
What version were you using? And what version helped you out?
Default 09-21-2011, 03:31 PM
I was using NBI 0.8.3, instead i used NBI 0.8.4 and it now works fine if i -v arch=i386
1012, cpu, unsupported
« Broke my multi-boot, need some help | Help: Osx panic on my 1012? »
