dbanga dbanga is offline
Default Snow Leopard 10.6.8 Help - 08-03-2011, 12:26 PM
I recently put mac os x snow leopard 10.6.3 on my dell mini 1018.
just a simple question, is it possible to update it to 10.6.8 via system update.
if so can somebody tell me how.
thank you.
bjsessions bjsessions is offline
Default 08-03-2011, 02:18 PM
Simple answer, No!
You'll need to download the combo update from apple (just google it or search there support site). You'll need to follow the 10.6.8 thread on this site, The FINAL 10.6.8 update thread.
Jump to post 22, (page 3) which links to Prasys's guide and has the main instructions, but read the additional comments as they are important (particularly damio's update guide #26).
Prasys's instructions are easy to follow but make sure you type perfectly!
Bon Chance!
« Help needed osx newbie | Upgrade from 10.6.3 to 10.6.7??? »
