| Senior Member Posts: 106 Join Date: Jan 2009 Location: France | What about the Extra folder ? If i want to delete the vaio kext for instance. The fact is, when i unpack my mkext from extra i can see acard kext, ati, nvidia so.. How could i pack it again without update.app ? |
(#4)
| Senior Member Posts: 229 Join Date: May 2010 | Quote:
Extensions.mkext located on System/Library/ isn't used anymore on Snow Leopard, the Extensions.mkext on Snow Leopard is located on System/Library/Caches/com.apple.kext.caches/startup/ It will be rebuild automaticly if we delete it, any kext on Extra will not loaded to it. | ||
(#5)
| Senior Member Posts: 106 Join Date: Jan 2009 Location: France | What mini do you got ? 9 ? If so, can you share your nbi ? Did you run update.app after 10.6.8 upgrade or it will screw something ? |
(#6)
| Senior Member Posts: 229 Join Date: May 2010 | It's 10v Quote:
I don't actually update my mini to 10.6.8, it's 10.6.8 with mach_kernel and system.kext from 10.6.7. | |
(#7)
| Senior Member Posts: 106 Join Date: Jan 2009 Location: France | You can purpose it to the 10v community then. I won't use it on mine. I guess it will screw something ! ![]() |
(#8)
(#9)
| Senior Member Posts: 106 Join Date: Jan 2009 Location: France | I ran update.app and their is no problem after it. I don't really need NBI now.. I delete almost all the kext i don't need. |
